Author Topic: I need help identifying my hot tub  (Read 6586 times)
Shimdon
« on: May 27, 2016, 12:49:57 am »
I got one for free from the mother-in-law and I need help identifying what it is. They piped it for natural gas, but I want to revert it back to electric and need some help with all of that. Here are some pictures. Let me know what other info you need
http://imgur.com/YMMqED4
http://imgur.com/GK8FqGx
http://imgur.com/8Q0SW06
http://imgur.com/rK7uEKQ
*fixed* sorry, I swear I put them in there
« Last Edit: May 29, 2016, 04:11:50 pm by Shimdon »
Re: I need help identifying my hot tub
« Reply #1 on: May 28, 2016, 01:02:49 pm »
there are no pictures.
SoCal Monkey
« Reply #3 on: May 30, 2016, 03:29:19 pm »
Looks to me like the answer is in that second picture. I would guess:
Manufacturer: American Spas
Model: HT100-15
Serial #: 940621-154
That's just my best guess, not a confirmed fact, but Googled American Spas and came up with this support page for American Spas, where you could probably follow up for confirmation and/or help if it's one of theirs:  http://www.american-spa.com/ContactUs.aspx
Good luck
Shimdon
« Reply #4 on: May 30, 2016, 03:49:51 pm »
I've already done that. It was built before April 2010, so it's not the same company
I just want to wire it up and probably get a new heating element. I need to know which one to get though. Will this one work?
https://www.amazon.com/gp/aw/d/B00COADPOC
« Reply #5 on: May 30, 2016, 08:03:12 pm »
   Yes that one should work.  There are 2 other sensors to the right of the heater leads.  One is probably a temp and the other is high limit.    Also you might as well change that pressure switch as well.  They are cheap and it would be a pain to put it all back together and find you need a new one.   It's funky looking thing with 2 wires to the left.
« Last Edit: May 30, 2016, 08:08:09 pm by Jacuzzi Jim »
Shimdon
« Reply #6 on: May 30, 2016, 08:46:22 pm »
Will this guy work?
http://www.amazon.com/gp/aw/d/B003BGD1KQ/ref=mp_s_a_1_1?qid=1464655402&sr=8-1&pi=SY200_QL40&keywords=hot+tub+pressure+switch&dpPl=1&dpID=310Sf8L%2BXLL&ref=plSrch
« Reply #7 on: May 30, 2016, 09:14:57 pm »
 Yes, just use a few wraps of Teflon tape, before threading it in. Do not over tighten.
    When you change the element, you have to very careful when tightening it and use 2 wrenches.  One below the main nut and one for the main nut.   I think one is 3/8ths and the other 1/4" been awhile since I have done it, but the goal is not to twist the leads that the wires go to on the heater.
Shimdon
« Reply #8 on: May 31, 2016, 12:25:24 am »
Cool, thanks. I don't know the last time they ran it. Like I said, they used natural gas instead of electricity. Should those two things get it to good running order? How/when will I know if the pumps are shot? And which ones to get in case?
MarKee
« Reply #9 on: May 31, 2016, 12:53:42 am »
This is most likely an American Spa that was made in Woodburn, Oregon. I believe they have been out of business since 2000-2001. Rumored to be shut down by the IRS.
« Reply #10 on: May 31, 2016, 12:02:57 pm »
 In a perfect world, yes it should work.
    The pumps will either work or not, or they will be louder than a Metallica concert and you will need to swap them out.  You have a lot of variables working against you to just say sure it will work. And were taking about a hot tub that's been sitting for how long?    Where did you score the equipment pack and how old was it?
Shimdon
« Reply #11 on: May 31, 2016, 11:47:38 pm »
It all came with it. They even gave me the gas heater if I wanted to use it too. I just wanted to get it out of there and home haha
I've got everything to wire it up and then I'll test it
