Author Topic: New spa pump /wet end  (Read 3988 times)
Jakeesspoo
« on: May 04, 2016, 11:00:03 pm »
    Im new here to the forum.    I have a older (2005 maybe) master spas legacy tub that i inherited     The two speed pump went bad so i ordered a new one from spa depot.   The old pump wet end/volute discharge had a small "port" on it that a small maybe 3/8" hose hooke
d up to.   I believe this hose then went to one side of one of the jets and maybe teed in with the other smaller diameter tubes (each large jet has a small diamter hose and a large diameter hose going to it).    The new pump I ordered is same ratings but does not have the "port" for the smaller diameter tubing on the volute/discharge of wet end.   What should I do?   What is the purpose of this smaller diameter hose that hooks up to discharge side and why cant i seem to find a identical one online?   spa depot has been of no help so far.      Any thoughts would be appreciated greatly as there are no spa techs in near vicinity or I would have them doing this
Re: New spa pump /wet end
« Reply #1 on: May 05, 2016, 09:34:39 am »
 It's most likely a air bleeder tube and has nothing to do with the jets.  Just find a way to plug it and leave it hanging.
« Reply #2 on: May 05, 2016, 11:27:54 am »
From the description you gave Jetpack Jim is right, plug the hose that previously went to the pump's bleed line and you'll be set.
« Reply #3 on: May 05, 2016, 01:21:31 pm »
  Jetpack Jim   kinda catchy   ;)
« Reply #4 on: May 05, 2016, 01:49:12 pm »
Unless it's a freeze protection line. You can still plug it but you may affect your freeze protection. Is this pump 2 of a 2 pump system? You could always drill and tap a new hole?
Jakeesspoo
« Reply #5 on: May 05, 2016, 08:04:26 pm »
Yes its the two-speed pump of a two pump system.   Im not worried about freeze protection i winterize it.
Jakeesspoo
« Reply #6 on: May 05, 2016, 09:52:06 pm »
I will fill it and see what i get.
