Author Topic: Yet Another Patio question  (Read 13404 times)
39lasalle
Re: Yet Another Patio question
« Reply #30 on: September 07, 2016, 08:07:50 pm »
Can you get me a pic of where and how you got the electric into the tub?
39
tmaestas95
« Reply #31 on: September 08, 2016, 01:22:33 pm »
The Bullfrogs have conduit entrances on all three non-front sides.  I used the rear entrance - you just drill out where the marker is (through two layers of plastic) then feed the flex through into the equipment cavity.  The disconnect is mounted on the house, the conduit is buried for a short distance over to the tub.  My breaker panel is way on the other side of the house so there's quite a long run of conduit around the house.
39lasalle
« Reply #32 on: September 08, 2016, 08:18:22 pm »
Thank you,     What wire did you run inside?    4 individual #6 rated for underground is what I am thinking?
39
« Last Edit: September 08, 2016, 08:40:01 pm by 39lasalle »
tmaestas95
« Reply #33 on: September 08, 2016, 09:55:08 pm »
Correct.
39lasalle
« Reply #34 on: September 20, 2016, 08:29:13 pm »
How is your base holding up?    Do you see any settling issues as this is the route that I am going as well
39
tmaestas95
« Reply #35 on: September 21, 2016, 10:16:24 pm »
The base itself is fine and I've seen no noticeable settling thus far.  That being said, despite my best efforts, the tub is not completely 100% level but it's pretty darn close.  If I had to do it over again I would use a powered compactor to compact the base - I didn't have an easy way to transport a rental compactor so I tamped everything with a hand tamp.  The last layer of stone dust probably was not as compacted as it could have been, and when they slid the tub onto the base during delivery it did scrape off some small amount of dust.  It's not out of level enough to cause any issues so not really a big deal.
It's not rained here yet since I had the tub installed but I don't really expect that to cause any issues either.  The tub covers all but a couple inches of the base on all 4 sides.
