Author Topic: 2005 Sundance Cameo pump 2 doesn't work  (Read 1948 times)
frankpaul1
« on: March 21, 2016, 08:56:35 am »
Hi, hope you guys can help me out. We just moved into our new house and acquired a Sundance Spa Cameo in the deal. Very nice spa, just filled it up after cleaning it thoroughly.
But there is a problem. Pump 1 functions great, as does the blower. Pump 2 doesn't do anything. I hear a click in the relay box, but it doesn't do anything. I have switched the wires from pump 1 and pump 2 and pump 1 does work when connected to the button from pump 2. So no faulty fuses or other problems.
I thought it might be an air lock problem, but after draining the massage knobs as instructed in the manual still no power. Should I try loosen the hoses connected to the pump or is this not going to solve this?
frankpaul1
Re: 2005 Sundance Cameo pump 2 doesn't work
« Reply #1 on: March 22, 2016, 04:31:20 pm »
Got a tip from the local dealer to try and rotate the pumps crank with a screwdriver. This didn't help unfortunately. So I decided to open the capacitor room to check if I could find anything wrong there.
The capacitor does look a bit bloated, but if the screwdriver trick didn't work could it still help to replace the capacitor? Your help is appreciated.
« Last Edit: March 22, 2016, 06:58:16 pm by frankpaul1 »
« Reply #2 on: March 22, 2016, 09:41:08 pm »
 If you can get a capacitor, it would be worth trying before buying a new pump.
