Author Topic: Hot tub when sick  (Read 5028 times)
Jostudly
Hot tub when sick
« on: March 19, 2016, 11:01:52 am »
I have a bad flu with a slight fever of 98f and a bad chest cough. I am wondering if using my hot tub at the highest temp will help me fight off the virus?
Hot tub when sick
Re: Hot tub when sick
« Reply #1 on: March 19, 2016, 02:11:16 pm »
I don't know about others but when I you use my tub when sick I feel worse when I get out
« Reply #2 on: March 19, 2016, 04:12:51 pm »
Same here for anything flu like. If my body is running a fever it shouldn't need help heating myself up and I'd be worried that I'd be overdoing it and overheating myself.
« Reply #3 on: March 20, 2016, 12:23:24 pm »
98F is not a slight fever. Normal body temp is 98.6
« Reply #4 on: March 20, 2016, 09:23:40 pm »
I was thinking the same thing Tman but didn't want to say anything lol
The Wizard of Spas
« Reply #5 on: March 21, 2016, 12:59:01 pm »
Soaking in a hot tub opens the pores and helps release toxins.  It wont hurt the situation, as long as its 98 degrees or lower as noted by the posters above.
Compatico
« Reply #6 on: March 21, 2016, 10:21:00 pm »
As mentioned, 98F is normal...as long as you're not running a fever, the heat won't hurt. I've often used the hot tub with a cold...it helps to relax if you're aching and makes you feel better like any other time. I wouldn't go in if I felt I had a fever though...it doesn't take much to overheat and pass out when you have a fever.
