Author Topic: Just Curious!  (Read 4973 times)
sobe
  • Sundance optima owner
Just Curious!
« on: July 20, 2004, 04:45:26 pm »
How much time does everyone spend on proper maintainence of  the tub?
Just Curious!
Wisoki
  • YEEEEEEhaw
Re: Just Curious!
« Reply #1 on: July 20, 2004, 05:44:33 pm »
5 minutes 1 x per week. Any more than that and you are over thinking your water chemistry. Keep in mind, your water will never be perfect. Every thing that comes in contact with the water changes its makeup. Air, sun light, people, all affect the balance. Once you have it initially balanced, you should take a one time a week test and make your small adjustments. Sanitizer should be increased or decreased as needed based on usage.
Re: Just Curious!
« Reply #2 on: July 20, 2004, 05:48:55 pm »
For me, just a few minutes a week to add shock, and sanitizer if necessary.  Test only takes a minute.
Several times a year I change the water, replace the filters, and clean the cover.  But day to day maintenance consumes very little time.
Re: Just Curious!
« Reply #3 on: July 20, 2004, 05:57:21 pm »
Yep 5 minutes a week or every other (depending on usage) to test the water and a few seconds to put in dichlor after use. Filter rinse once a month cover cleaning 3 times a year.
Re: Just Curious!
« Reply #4 on: July 20, 2004, 10:30:52 pm »
What he said, except I rinse filters every two weeks. Your mileage may vary.
« Last Edit: July 20, 2004, 10:31:39 pm by wmccall »
Spa_Tech
  • Independent Spa technician
Re: Just Curious!
« Reply #5 on: July 20, 2004, 11:21:17 pm »
I maintenance several spas a week-
It works out to about an hour a month with water testing, adjustment, sanitation, cleaning the filter, cover, treating the vinyl with a protectant and vacuming.
johnnythunders
  • Jacuzzi J-355
Re: Just Curious!
« Reply #6 on: July 20, 2004, 11:22:01 pm »
Clean filters every 2 weeks,,,,,Since i bought 8 nature2s i think i will change my water about every 2 too 3 months.johnnyT :P
Re: Just Curious!
« Reply #7 on: July 21, 2004, 01:25:59 am »
3.47 min/wk plus cleaning the filters monthly (and any time I drain)
Re: Just Curious!
« Reply #8 on: July 21, 2004, 07:56:10 am »
3.47 min/wk
Aproximately :)  Spatech becomes  Spock.
Re: Just Curious!
« Reply #9 on: July 21, 2004, 08:04:23 am »
Spocktech T.U.O?  I like that!
autoplay
Re: Just Curious!
« Reply #10 on: July 21, 2004, 09:00:58 am »
Spocktech LOLOL.  At least if he's bestowed that title.....He can use with confidence the line......"I find that highly illogical Jim" ;)
Lori
Re: Just Curious!
« Reply #11 on: July 21, 2004, 12:48:37 pm »
LOL!!!!!
;D :) ;D :)
doodoo
Re: Just Curious!
« Reply #12 on: July 21, 2004, 12:55:23 pm »
Who was it that said.....soak long and prosper?
lol
Re: Just Curious!
