Author Topic: Newb Chemistry Questions  (Read 3572 times)
kellyjo7
« on: February 23, 2016, 10:48:15 am »
First, thanks for all the info on this site.
I just moved into a new house with a ~500 gal 2005 Cal Spa tub. I was able to drain and refill and have been working on balancing. I'm using bromine for sanitation and the hot tub has an ozone.
My hardness is normal if not a bit on the low side, forgot the exact number.
I was having issues with high PH ~8-8.1 and Low TA. Like around 30-50 if not lower.
My main question is that I seem to see conflicting info on here about how big of an issue low TA is. I was finally able to get PH in perfect range, but my TA is very low like around 30.
I added a little TA up from spadepot.com last night after I tested the PH. I haven't got a chance to re-test, but I am concerned that it will creep my PH up again.
I'm using a Taylor Bromine K-2106 test kit. My Bromine Level has been good, though it trends a bit on the high side (between 5-10, though it was actually a little low on Sunday, so I increased the dispenser and it's back in the 5-10 range, probably right around 6.5-7).
It's been about a month, and I've noticed some pretty decent water loss, we use it ~4 times a week. And I'm in South Dakota so it''s usually cold. So I imagine that's the reason for the water loss. I need to top it off tonight, so this A.M. I opened up the bromine dispenser up again to about 5.5.
So I guess my two questions are:
1. Is low TA okay, if I keep PH in proper range? If yes, how low is too low?
2. What do I need to consider/anticipate when topping off, I opened up the bromine because I figure when I top it off it will dilute the sanitizer, maybe this thinking is totally off. What will be the top off impact on my chemistry? I'm assuming I will kind of have to start fresh after topping off. I shock at least once a week with OxySpa MPS. Should I shock again after refilling?
Re: Newb Chemistry Questions
« Reply #1 on: February 23, 2016, 11:36:53 am »
The exact opposite situation I have.  I finally end up keeping my PH somewhere in the normal realm and let the TA fall where it may.
nymxracer
« Reply #2 on: February 29, 2016, 07:48:32 pm »
Full disclosure...... I'm new to this and won't pretend to know like some others in here do, but here it goes. I have the same concerns. My TA is like 30ppm and my PH is 7.4 so I'm letting it ride because when I tried adding baking soda to bring up the TA it shot my PH up to 8.5. and then when I added muriatic acid to drop the PH it pulled down my TA with it. One thing I noticed that helped my water quality was bringing my CH up from 50 to 150. Water seems softer and easier to maintain.  Again this is just my 2 cents, albeit an unexperienced 2 cents.
« Reply #3 on: March 02, 2016, 11:45:58 am »
The experts will tell you why baking soda is harder to get what  need reading wise, but when I read a post like yours,  I tend to suspect you might be checking the readings too often.   Most PH up products tell you to wait a certain period of time before re-checking.   With baking soda, I add a small amount and don't check again for a full 48 hours.   After 3 years with my current sized tub I know about how much to add.  If I add it slowly I can get my PH up to 7.4 or close by the TA can go a little high, but close to norm.
nymxracer
« Reply #4 on: March 02, 2016, 04:54:51 pm »
Your absolutely correct,  I've been checking my water twice a day. I'm going to scale that back to once every other day and tell Taylor mfg. to hold off on the extension to his house that I was funding. :) Thanks again and sorry to OP, I never intended to hijack your thread but hopefully you found some of this helpful.
« Reply #5 on: March 03, 2016, 07:30:28 am »
Instead of calling it chemistry call it baking and use baking soda and lemon juice
