Author Topic: How do you know if your tub is leaking?  (Read 8021 times)
Letran
« on: February 22, 2016, 07:50:14 pm »
I can see the bottom of my tub right now. It is on top of a clean concrete slab right now. The edges seems to be always wet. One side I would even say have a glimmer water.
I opened the pumps side of the tub looks like its all good.
The edge with glimmer is the other side. I have never opened any other sides aside from the panel where the pumps are.
Are edges of concrete slab always wet like this.
Now I can see the bottom of tub, but what happens when I sink this tub on a deck and you can't see the bottom?
Re: How do you know if your tub is leaking?
« Reply #1 on: February 22, 2016, 08:20:38 pm »
Is the tub losing water at a quick rate? Tubs do lose water but it should not be significant amount in say 1 week.
How high off the ground is the concrete slab? Is it flush with the ground or does it sit 3 inches high?  How wet of an area did you put it in? If you have a sand box then I would think water shouldn't be around but clay - yep.
If you open up your sides - feel the foam to see if it's wet. Shut the tub down, let it sit there for a week and see if it drained itself.
I had a leak as I noticed that I had a wet side on my tub. I also had to add a lot of water (2 to 3 inches) to the tub every few week without anyone using it. Since I kind of knew the side I decided after a very long while to takle it, let the tub drain to it's lowest level so I knew how high to look and it turned out to be a stupid easy repair.
Just a FYI and I believe most people do not think about leaks/repairs but you should be able to get to all 4 sides of the tub and also be able to remove the panels if need be.
Letran
« Reply #2 on: February 22, 2016, 08:42:15 pm »
Not at all maintain its water week to week no issues, when its mostly covered. Well as far as I can tell. I could say the last 2-3 weeks the water is about the same.
The slab is about 4 inches off the ground.
The concrete slab walls are completely dry. its only about an inch directly touching the bottom of the tub that has this wet look. I can see the wet look concrete around the tub. I opened up panel where the pumps are located and everything seems dry from the inside.
I haven't ventured to open any other sides aside from the pump side. still a bit chilly to work outside +/- 3deg C
My Artesian Spa Dealer says "Artesians don't leak" I'm really crossing my fingers hoping he is right. I'll be opening up other panels when it gets slightly warmer.
« Reply #3 on: February 23, 2016, 09:40:31 am »
"My Artesian Spa Dealer says "Artesians don't leak" I'm really crossing my fingers hoping he is right. I'll be opening up other panels when it gets slightly warmer."
hahahahahahahahahahahahahaaaaaaaaaaaaaaaaaaaaaaaaaaa
Anything, that holds water can eventually leak. ANYTHING! This includes ANY spa, with all it's plumbing and equipment and everything glued and attached together. In fact, I can GUARANTEE you that eventually, EVERY spa will start to leak.
« Reply #4 on: February 23, 2016, 10:45:19 am »
  Plus 1
  I think you would know by now if it was leaking by what your describing. You would be adding water daily or a couple times a week. Most times you would see a trail of water coming off the slab. Spa's with complete bases will hold water before leaking sometimes.  Like suggested I would open a panel or two and stick your hand down in to the btm see if it's wet.
Letran
« Reply #5 on: February 23, 2016, 01:45:55 pm »
What!!! I was lied to!!! :-)
I never believed it, but I wanted to repeat it anyway. It is comical.
I knew it could leak at some point, but its less than three months old!!.
When it gets warmer I will open up the other panels. I'm a bit afraid what I might find out. But I guess better now than later
« Reply #6 on: February 23, 2016, 07:11:47 pm »
Call that dealer who said it would never leak and tell him you suspect a leak. Have him look at it. Maybe he can explain it as condensation from the cover, or a particular spot on the side that splashes over easier.
Letran
« Reply #7 on: March 07, 2016, 03:46:09 pm »
Okay since I suspect leaking I'm monitoring the water level
Since I used it last which was last weekend Sunday, Feb 28
from Sunday to Sunday yesterday March 6th, my water level is an inch and a bit lower.
The tub is always covered unless it is being used. I did not use it for a week and the water level is bout more than an inch lower.
Is that a concern. Is that normal?
And no unfortunately still have had a chance to open the other panels to see. (its still cold outside) I just opened to pump side panel and it was completely dry there.
Thanks again in advance
« Reply #8 on: March 08, 2016, 01:24:06 am »
I vote for leak
« Reply #9 on: March 08, 2016, 05:44:54 pm »
I vote for leak
Yeah, I think it may be.
« Reply #10 on: March 08, 2016, 06:59:37 pm »
 Plus 3  Guessing the dealer will tell you it's the first one.  Hope they get it taken care of for you.
