Author Topic: Adding 2 different chemicals at the same time  (Read 3498 times)
Jostudly
« on: February 13, 2016, 02:39:11 pm »
When I add my chemicals I run the jets for 20 mins for each one. Since it is a cold day today I added my ph reducer and crushed bromine at the same time. Does this matter or not? Also can I add stain an scale and poly sheen at the same time? Is there any chemicals that I need to let the jets run by themselves?
Jostudly
Re: Adding 2 different chemicals at the same time
« Reply #1 on: February 24, 2016, 05:00:48 pm »
Could someone please answer my question. Thanks
« Reply #2 on: February 24, 2016, 05:06:58 pm »
Bromine and oh reducer should be fine. Poly sheen I have no idea about though
« Reply #3 on: February 24, 2016, 05:28:32 pm »
Are you adding Stain and Scale and Poly Sheen cause you have to or because someone told you to?
Are you adding PH reducer because you have to?
Jostudly
« Reply #4 on: February 24, 2016, 08:35:06 pm »
Yes my ph is over 8 every week and my dealer recommended the polysheen for water clarity and stain and scale for the pipes to stay clean.
