Author Topic: J-470 side 2 jets don't come on  (Read 2431 times)
JeromeMerlau
« on: December 30, 2015, 04:48:47 pm »
Hi, I am Jerome and I am a complete rookie!
Ok. I feel better now
Bought a new home with an existing tub and I'm just now trying to get it going. The jets on the right side as I stand at the control panel will not activate. I hear the lump try and then nothing. I've messed with all the aincontrol flow knobs with no luck.
I'm open to suggestions I can try.
Re: J-470 side 2 jets don't come on
« Reply #1 on: December 30, 2015, 06:25:41 pm »
 Might be a airlock in the pump, how long does it run for?   Sometimes you can turn the pump on, then unscrew the cap to the divertor and the air will bleed out that.  The divertor is that thing on the right side with a handle that should turn to the left then the right.  When it's pointed to the center of the spa it will send flow to both the corners.   Might work.
JeromeMerlau
« Reply #2 on: December 30, 2015, 09:48:23 pm »
Thanks Jim. I will give that a try.
