Author Topic: Foam after adding acid?  (Read 2319 times)
Gibson00
« on: December 20, 2015, 12:43:33 pm »
In the past two weeks, I've once per week added a cap full of acid (about 25 grams I think), Arctic spa brand, to bring the ph down. I always run the jets after adding anything. Both times when adding acid and turning on jets, I had soapy foam develop on top of the water. Only time this has ever happened. Normal??
chem geek
Re: Foam after adding acid?
« Reply #1 on: December 20, 2015, 06:12:50 pm »
That's not normal, but it is possible for the pH of the water to affect the stability of foam -- as for what pH is more stable, that depends on the type of chemical making up the foam.
Your Arctic Spa pH Down product is likely 93.2% sodium bisulfate.  See if it lists the ingredients on the bottle.  It's unlikely they added something to the product that causes foaming.
