Author Topic: how much ppm chlorine shock to add to reverse excess chlorine demand?  (Read 2459 times)
HotTubster
Chlorine goes from 8ppm to 1ppm in 24 hours.
How much do I need to add to shock to get things back to more normal?
Thanks.
Re: how much ppm chlorine shock to add to reverse excess chlorine demand?
« Reply #1 on: December 04, 2015, 11:15:48 pm »
What is your stabilizer level? Too much stabilizer reduces the effectiveness of the chlorine.
To answer your question though I would probably add about 6 oz of regular bleach ... should bring you to about 10 PPM or more and will not raise your stabilizer. I would then test the water in the AM and see if the chlorine dropped a lot (if you can test possible high chlorine - actually anyone can, just a little math) and add more if need be. The question is a hard one to answer since there are a lot of variables to the water itself and how much the chlorine is trying to kill.
HotTubster
« Reply #2 on: December 05, 2015, 01:01:02 am »
Thanks ... stabilizer is good. Ran Dichlor for a week to get to 30ppm.
