Author Topic: Water/Chemical levels questions!!!  (Read 7045 times)
Gibson00
« on: November 21, 2015, 04:01:50 pm »
Hi all, 2+ weeks into spa ownership, Arctic Summit.  My water has been pretty good, but have been struggling a little bit with the pH and Alkalinity...
I keep adding the baking soda product, but my levels would still stick around 40-50ppm for alkalinity.  And Id add adjust down for the pH, but they seem to want to stick around 8.
So finally I did manage to get the alkalinity up to about 100ppm, but the pH is still sticking around 8.  Should I keep adding ph down to try to lower it?
The guy at the Arctic store seemed to think my alkalinity was actually a bit high, and that I had to lower it before i could lower pH??
OK, the other thing, is that I bought another brand of test strips to try, more than anything to double check the readings I was getting.  These new strips happen to have a check for hardness too.  Well, it turns out my total hardness was bottomed out, literally near zero.  So the place I bought that from said I should definitely adjust for that, and sold me a calcium product.  I went ahead and added enough to bring the hardness up to about 100ppm.
But now, aside from still trying to get the pH down, I now find my water has a different feel to it, almost like a chalky/base feel to it on the hands, whereas before it was silky smooth.  It still looks clean, no foam, no ring around the border.  So I called the Arctic dealer and asked them, and they said they never recommend bothering checking the water hardness for their spas.....ugh...OK....no idea why, but now I wonder did I make a mistake adding the calcium..
Oh, and if it matters, my chlorine is consistently on the slightly high side, probably about 6-7ppm.
What should I be doing?  I feel like I am brewing a chemical soup here!  Help!
« Last Edit: November 21, 2015, 04:37:21 pm by Gibson00 »
Re: Water/Chemical levels questions!!!
« Reply #1 on: November 21, 2015, 05:50:23 pm »
being a newbie (I assume) to water care can be daunting and the first moth of ownership will have you adding stuff into your water because you don't know. Chas' Law - Change the water after the first month of ownership!
But to your "problem" - you don't need to worry about calcium, I believe if you have a gunite (concrete) pool the water will leach it out of the walls if it's not at the right level. Other than that - no need to worry; the opposite is not true - too much calcium will possibly deposit stuff on your spa shell. With that said when I was new to spa ownership - I did worry about calcium because the Taylor book said so! I wanted my water balanced.
Unfortunately you need to know where you started from before you know how to proceed - easy enough by taking a sample of your tap water if that's where you got your spa water from. My water tends to be low alkalinity and pH so for me I can add baking soda and both rise and pretty much lock in. I can also add borax to raise just my pH. If out of the tap you have high pH then you need to add acid to drop it but if it's locked in because of the alkalinity then you need to add enough acid to drop that first. Non chlorine shock has a pH of about 4 as well and if you use that pH will eventually go down.
I don't see the need to lower anything - yes it's high but it will come down with the addition of chlorine (dichlor) and especially if your using trichlor which is acidic (if I remember correctly you are using a puck). As far as your chlorine (again if you are using a puck) is there a way to adjust the flow of water going into the feeder?
av8r
« Reply #2 on: November 21, 2015, 08:14:24 pm »
Listen to Vinny.
Throw the test strips in the garbage.
Go to Amazon and order the Taylor K2006 test kit (if you're using chlorine).  Then go to Youtube and watch the K2006 videos to learn how easy it is to accurately test your water.
Relax about water chemistry and enjoy your tub.
Quickbeam
« Reply #3 on: November 21, 2015, 08:29:19 pm »
Agreed that low calcium is not an issue, unless you have foaming. My calcium is not low, but if I remember correctly low calcium can cause foaming???
Gibson00
« Reply #4 on: November 21, 2015, 11:12:11 pm »
Thanks all.
So, now that I have added calcium, should I add one of the products to remove minerals, or just leave it?
I hate to drain all the water out, seems like a waste.  I'm in Nova Scotia and winter hasn't really hit yet, but shouldn't be too long.  I was hoping I'd make it through to beginning of March before having to do a drain..
« Reply #5 on: November 21, 2015, 11:53:46 pm »
No, leave it. Or you can do a partial water change (1/2 the tub) if you really don't like the feel of the water.
Quickbeam
« Reply #6 on: November 22, 2015, 08:33:27 am »
If you really want to learn something about water chemistry and how to balance your water, this is one of the best write ups I've found (http://www.poolspaforum.com/forum/index.php?showtopic=13634). And remember a couple of things. Despite what the write up says, Vinny is correct in that CH is not that big a deal. Too much CH can lead to deposits being left and too little can lead to foaming, but other than that it is not a huge deal. And secondly, I want to second what av8r says - get yourself a Taylor test kit!
sksmoker
« Reply #7 on: November 22, 2015, 02:15:45 pm »
Being in Canada, like myself, you are going to have to go to ebay and buy your K2006 test kit (for chlorine). The exchange is brutal, but it is worth it. Test strips that are good, you won't really find up here either. About all I use test strips for is for chlorine levels.  I just changed my water on Tuesday so you'll make it to March like myself without issue.
Do you have a floater with mini chlorine tabs in it by chance?
Print out that post by nitro for water balancing. You'll be referring to it a lot if you are like myself for the first 6 months or so of ownership.
Get your TA sorted out first. Then worry about PH. Get some Borax from Walmart. 20 Team Mule Borax, it is in the cleaning section with the dishwasher detergent. You'll need this to push up PH if it is too low when you get your TA sorted.
PH can be really stubborn to get down. You just have to keep adding and testing to get it right. Once the PH breaks, it will come down so you don't want to overshoot it too much.
The taylor kit is key here. I don't know what I would do without it. I know the majority use strips but they are so vague..
One other quick suggestion is that once you get your kit, test it and compare against your strips. I did this so I know that my PH/FC/TA is either low or high by X amount on the strips if I can't use the test kit (-30C comes to mind!) and I made a note of it. I know my strips are low by 1ppm on my FC strips. The reagents are expensive to get with the kit, so order the 2 oz replacements when you order them. This way when you run out or have to wait from ebay for the reagents, you'll be ok with the strips until your refills get to you.
Quickbeam
« Reply #8 on: November 22, 2015, 03:23:06 pm »
sksmoker,
Just curious where in Canada you are located? We are in the Vancouver area.
Gibson00
« Reply #9 on: November 22, 2015, 10:15:49 pm »
Thanks again all.
My chlorine - I am using the small Spa Tabs.  About the same size around as a Canadian Loonie coin, and about half inch thick.  It goes into a small plastic holder just big enough to hold the tab, and that goes underneath one of the filter covers.  This is where the arctic folks told me to put it.  Seems to have worked out OK so far as my chlorine levels have been pretty stable.
Re the Taylor kits, yes, very hard to get to Canada!  Only found one ebay seller that ships to Canada.  They want about $70 US for the kit, and $60 US for postage!!!!  I am heading to Florida in March, so may pick one up while I'm down there...
OK, so, the feel of the water was driving me kind of nuts, so I said screw it and drained about 80% of it today and refilled, starting over.  I think I have the TA balanced and the pH looks OK, if anything maybe still a tiny bit high.  Will not be adding calcium!  Waiting for the temp to come up and will retest the water..
Gibson00
« Reply #10 on: November 22, 2015, 10:39:46 pm »
OK, just had a look on ebay, and found another seller shipping to Canada.  Ordered the Taylor k2006 kit, came to about $90 US shipped.  Might owe some import tax at the post office if it gets inspected, kind of hit or miss...
« Reply #11 on: November 23, 2015, 07:25:46 am »
Since there no way to control the flow of water to the chlorine puck - your chlorine level will stay the same until it either dissolves totally and the chlorine is used or you pull it out. You may want to contact the dealer and ask them about the high chlorine amount - they may have a suggestion. 6 PPM is high although I have soaked in higher but not for extended periods of time. Don't be surprised if the dealer doesn't have a clue or says it's OK ... I once went to a pool dealer for high stabilizer (over 100) and the dealer said that that's what they shoot for! NO!!
I tried looking at an Arctic Spa manual and they mention a floating feeder where you can adjust the amount coming out - unfortunately this is not what you have.
Gibson00
« Reply #12 on: November 23, 2015, 08:19:01 am »
Vinny - The Aquafinesse kit they sold me actually came with another free bottle of the spa tabs and a floater device, looks like a little blue and white UFO.  I just didn't bother to use it, stuck with the tiny plastic container placed in the filter cover that they recommended on delivery, since, again, it seems to be keeping the levels pretty stable.  Is it bad/unhealthy to have the chlorine level on the slightly high side of the 'good' range on the test strips?
Thx
« Reply #13 on: November 23, 2015, 10:35:57 am »
I don't think there is a health risk except if you're sensitive to chlorine. Other issues may be with bathing suits if you use them as they may fade or deteriorate quickly.
Here is a World Health Organization report: http://www.who.int/water_sanitation_health/bathing/srwe2chap4.pdf
They mention something about 5 mg/l for hot tubs and drinking water which is 5 PPM, slightly less than what your measuring.
sksmoker
« Reply #14 on: November 23, 2015, 12:12:19 pm »
sksmoker,
I'm in South Sask. About 24hrs drive from Vancouver :)
