Author Topic: Can I get in hot tub right after adding chemicals  (Read 14105 times)
Jostudly
« on: November 13, 2015, 08:39:47 pm »
I have use bromine in my tub. I run the jets for 20 mins when adding each chemical. Can I get in the hot tub right after I balance my ph and cal hardiness or do I need to wait? Bromine level is fine.
MarKee
Re: Can I get in hot tub right after adding chemicals
« Reply #1 on: November 13, 2015, 08:50:58 pm »
It depends on how much you're putting in, you're probably fine with calcium hardness increaser and pH/alkalinity up and down.  But if you get a concentrated amount of that on your skin, it might get irritated.
I would definitely wait awhile after putting in oxidizers such as shock, chlorine, and bromine.
Jostudly
« Reply #2 on: November 14, 2015, 08:58:47 am »
How long should I wait when adding shock?. I use a floater for bromine so I take that out of the tub while I am in it.
« Reply #3 on: November 15, 2015, 08:32:49 am »
No need to wait.
Jostudly
« Reply #4 on: November 15, 2015, 10:23:09 am »
Okay thanks
« Reply #5 on: November 15, 2015, 10:44:16 am »
If you are using MPS then you should run the jets for 20 minutes as it says on the bottle. After that you're good to go.
