Author Topic: 2015 J-470 60 AMP Mode  (Read 3369 times)
earlfish
« on: October 26, 2015, 04:35:40 pm »
Taking delivery of my 2015 J470 Platinum/Teak tomorrow. I've been doing research and found that older models required some modifications to enable 60amp mode.
I can see that I have to set dip switches in the control panel to set 60amp mode per the user manual, but is that it. I know prior models needed some changes in an engineering mode in the J-1000 control, but the 2015 has the J400 protouch controller. Does this require something special as well or just the dip switch settings.
Any ideas?
« Last Edit: October 26, 2015, 06:35:55 pm by earlfish »
Re: 2015 J-470 60 AMP Mode
« Reply #1 on: October 26, 2015, 05:54:46 pm »
  On the J 1000 controller you it through the keypad.   No dp switches.
earlfish
« Reply #2 on: October 26, 2015, 06:20:20 pm »
The 2015 doesnt come with the J1000 anymore. Its a new controller the ProTouch. I know for a fact per the manual there are dip switch settings for 60amp, but what I can't determine is if there are additional things you need to do on the protouch controller
« Last Edit: October 26, 2015, 06:34:07 pm by earlfish »
earlfish
« Reply #3 on: October 26, 2015, 08:11:44 pm »
duplicate post
« Last Edit: October 26, 2015, 08:49:27 pm by earlfish »
icenogle
« Reply #4 on: October 26, 2015, 09:27:53 pm »
Good luck with your Jacuzzi delivery.  Hope you break the cycle:  Robrob - damaged, Amy - wrong color, mine - damaged.  All Jacuzzi, but loving mine now.
« Reply #5 on: October 26, 2015, 10:42:56 pm »
 If they have in-fact changed it and there are jumpers/dp switches my guess is that's all that will need to be done.  We are no longer a Jacuzzi dealer but I didn't hear about any changes prior to that, which has only been a few weeks.    You said in a PM your dealer isn't very helpful, but for 13000 dollars or more (guessing) they should be.  ;)
