Author Topic: Confused! Added Ozone and now bromine levels dropped!  (Read 5322 times)
jmauceri
« on: October 07, 2015, 04:47:40 pm »
I have a 2008 Marquis Epic with the Spa Frog System.  I use my tub every day and after trial and error I found my water would balance well if I shocked (non-chlorine) every time I used the spa.  After some time I realized my Ozonator wasn't working.  I said "ah ha! that's why i have to shock daily to keep by bromine levels where they should be".  So I replaced the tube style stock ozonator with a Del Ozone MCD-50 ozonator and figured life would be good.  Well the opposite seems to be.  Unless I shock daily my bromine levels read zero!  Before knowing this, and after a few days of not shocking, my water started getting cloudy.  What's up with that?  I thought ozone helped reduce chemical use.  I'm going through more shock than ever!
If a chemical genius could explain this to me I would greatly appreciate it.
FYI Spa Fog at setting 4 and PH, Alkalinity and CH at the middle of the spectrum.
chem geek
Re: Confused! Added Ozone and now bromine levels dropped!
« Reply #1 on: October 07, 2015, 08:32:10 pm »
Did you ever add sodium bromide to create a bromide bank?  If not, then the ozone has no bromide to convert to bromine.  Eventually your addition of bromine may build up a bromide bank, but initially you need to create one.
jmauceri
« Reply #2 on: October 08, 2015, 09:43:41 pm »
Wow,  I had no idea. Thank you so much. Why wouldn't marquis include that little tidbit in their startup instructions for the Spa frog system with the ozonator?
jmauceri
« Reply #3 on: October 09, 2015, 03:01:39 pm »
Sorry to be a pest, but would the Spa Frog Jump Start pack of Sodium Dichloro-s-triazinetrione provide the base bromide?  I'm due for a routine water change, so I'm wondering if I need to still add the sodium bromide to the new water.
« Reply #4 on: October 09, 2015, 06:56:29 pm »
No
dave48103
« Reply #5 on: October 10, 2015, 11:38:13 am »
How did you know your ozonator wasn't working? I've often wondered about that with our spa. I know there's a stream of water coming out of the outlet, but how does one know that the ozonator is actually doing anything?
jmauceri
« Reply #6 on: October 10, 2015, 10:13:46 pm »
A few different ways. First,  the O3 message on my display would only stay on briefoh. Second,  there was no glow from the ozonator itself. After I replaced it,  is completely obvious because I can now smell the ozone.
jmauceri
« Reply #7 on: November 27, 2015, 10:38:26 am »
I want to give an update to this thread.  Chem Geek was dead on with his advice.  I performed a water change and I used the Spa Frog Starter packet along with Sodium Bromide.  It's been over 4 weeks now and my water has been crystal clear from the beginning and I'm now only shocking one a week with the ozonator running well.
Chem Geek, thank you so much for the advise!  I still don't understand why the manufacturer wouldn't recommend the Sodium Bromide.
Regards,
Joe
chem geek
« Reply #8 on: November 28, 2015, 01:32:04 am »
There are lots of things about pool water chemistry that manufacturers either don't know or don't tell.  However, most do recognize that for a bromine system one usually starts out by creating a bromide bank by adding sodium bromide.  That was a pretty lame mistake for them.  Most don't understand the chlorine/CYA relationship and many don't understand the TA/pH relationship.  There are good ones that do understand these things; you'll find them on this forum.
« Last Edit: November 28, 2015, 01:33:53 am by chem geek »
