Author Topic: New Jacuzzi  (Read 10756 times)
amy2421
New Jacuzzi
« on: September 30, 2015, 08:04:33 pm »
I figured I'd better post a positive thread about my new Jacuzzi so it doesn't seem like I'm down on it just because of a negative initial experience. :)
Our J-470 is in place, wired up, but not filled yet. I'm not super happy about that, but we are in the last couple days of a major backyard reno so there is still a lot of sawdust and polymeric sand flying around. My husband doesn't want to fill it until they are almost finished.
The Roasted Chestnut skirt seems to have a haziness that I thought I could wipe off but it keeps coming back. Any suggestions for how to improve that or is it just "how it is"?
I spent some time inside the tub this evening cleaning out the interior. There was a lot of "stuff" inside.... bits of dirt/grit, several dead bugs, along with the expected water from the factory's wet-test. I wiped it down, got out the majority of the "stuff" and all the dead bugs, and will probably give it another better wipe inside before we fill it. (Maybe...)
The interior is gorgeous. The Platinum shell is so lovely and smooth and shiny. Every mark that I found wiped off and it seems completely flawless and free of even a scratch. The jets look good, albeit a little dusty and with bits in them like the rest of the tub, so I wiped most of that out and I figure the water and pressure will blow out anything that I can't get.
Just sitting in it dry reminded me of why I love this tub. Can't wait to get it filled and fire it up for the first time! Hopefully this weekend! :) :) :)
New Jacuzzi
Re: New Jacuzzi
« Reply #1 on: September 30, 2015, 08:21:49 pm »
  Try pledge on the skirt.
amy2421
Re: New Jacuzzi
« Reply #2 on: September 30, 2015, 08:25:29 pm »
Thanks Jim! I will try that!
orlando1
Re: New Jacuzzi
« Reply #3 on: September 30, 2015, 10:23:18 pm »
Can't wait to see pics.
SoCal Monkey
Re: New Jacuzzi
« Reply #4 on: October 01, 2015, 02:03:23 pm »
I'm looking forward to the pics, too. Hope you love it.
amy2421
Re: New Jacuzzi
« Reply #5 on: October 01, 2015, 04:59:40 pm »
Thanks! I don't know how to post pics on here though...
SoCal Monkey
Re: New Jacuzzi
« Reply #6 on: October 01, 2015, 08:12:41 pm »
Back out to the main forum index and there's a forum for sharing spa pics. Here's the topic from that forum explaining how: http://www.whatsthebest-hottub.com/forum/index.php/topic,17532.0.html
amy2421
Re: New Jacuzzi
« Reply #7 on: October 02, 2015, 10:22:56 pm »
Today we finally got to fill up our Jacuzzi!!! It did not take as long to fill as I thought it would. Then the moment of truth.... flipped the breaker on the GFCI and our tub fired to life! :) So great news... it works and our electrician wired it up correctly. :)
We put in the startup chemicals, ran the jets for 20 minutes, and now we're watching the temperature rise on our free remote. :) It started at 63 degrees and we're presently up to 71 (in about 90 minutes)... it is only about 50 degrees outside right now.
The Champagne is in the fridge ready to go when it gets up to temperature... (whether that is tonight or tomorrow, doesn't matter).  :D
Quickbeam
Re: New Jacuzzi
« Reply #8 on: October 02, 2015, 11:00:04 pm »
Congratulations Amy!!!
I know you've been through a lot with your spa purchase. Is really nice to see it all come together. Hope you enjoy it for a long, long time!
amy2421
Re: New Jacuzzi
« Reply #9 on: October 03, 2015, 11:09:37 am »
Thanks Quickbeam! This morning I checked the remote and the temperature was up to 101 and holding. I've bumped it up to 102 and it came up pretty quickly. Everything seems to be operating perfectly! :)
We had a Jacuzzi technician here first thing this morning to change the factory default setting of 50 amp to the 60 amp setting so that it can run the heater and both pumps at the same time. (Everything is wired for 60 amps - you should see the size of the wire!! - and the breaker in the panel is 60 amps.) I have the instructions for how to do it, but there was some suggestion that you can void your warranty by going into those settings so I figured it was a free service call so why not?
Tonight will be our first dip... can't wait!
Quickbeam
Re: New Jacuzzi
« Reply #10 on: October 03, 2015, 11:39:56 am »
Enjoy! Enjoy! Enjoy!
I also think you're smart to wire for 60 amps. It's a long story, but we went through quite a bit to get ours wired for 60 amps (we have the Jacuzzi J-345). I'm so glad we went to the trouble to get the 60 amps. Certainly haven't regretted doing that.
amy2421
Re: New Jacuzzi
« Reply #11 on: October 03, 2015, 12:19:59 pm »
The first electrician who quoted us was going to run a 50 amp rated wire and 50 amp breaker, and told us to run the 60 amp setting on the tub and it would work fine. While that may be the case, it didn't sit well with us (or others on this forum who weighed in.) The second electrician, who did the work for us, wouldn't even hear of wiring it as 50 amp and automatically said he would do it the right way (and his quote was $400 cheaper!)
orlando1
Re: New Jacuzzi
« Reply #12 on: October 03, 2015, 01:29:27 pm »
Yeah with so many electricians out there, finding the right one is hard. I had several at my house before I settled on someone I felt comfortable with. Man it's shocking who they let have electrician license these days. And no these weren't independent electricians in business for themselves(though that's who I ended up going with), but these were from larger companies that employs several electricians. Most of them were suggesting I violate pretty every code in the business. Just to give you an example....mounting the gfci panel right beside the power meter on the side of the house which is no where near being in the line of sight from out hot tub in the back yard on the opposite side of the house, only digging the trench 3-4 inches to buying the cable. And their quotes were by far the most expensive.
Even the one I ended up going with(I bought my own parts), thought I was insane to run 6 awg wire for a basic hot tub install. He wanted to go with 8-10 awg. When I told him I needed that size to run 60 amps, he really thought I was insane. Why on earth would I need 60 amps for a hot tub he said. I was just as shocked at his thinking. But with 40 years of experience and his willingness to do what I wanted vs doing what he thought I should have like the rest, I went with him. The people who installed the hot tub had no trouble configuring the panel inside the hot tub for 60 amps. Some said I wouldn't need it here in AL. But I've been running the heater in economy mode and there has been a few nights here lately it's been down in the 50s and 99 degrees just wouldn't be quiet warm enough. It's been nice to get in at 99 with both pumps running and turning the heater on at the same time. Only takes a few minutes to get it up to 101. If I have had to turn the heater on this many times already with both jets running, there's no telling how many times I would have to do so once it actually gets cold here. I would recommend anyone, anywhere to go for the 60 amp install. You'll never know when you might need it, and once you do, You'll be glad you did.
And finally, congrats Amy on getting everything up and running. It's been a long road, but your patience is finally paying off and the wait is definitely worth it.
Quickbeam
Re: New Jacuzzi
« Reply #13 on: October 03, 2015, 02:03:23 pm »
We had a similar situation. We recently built a new lakeside home. We had a fantastic general contractor, and I have to say the electrician was good in what he did, except for the hot tub wiring. Our hot tub was going on a roof deck, and all the wiring was run during the construction of the home. There was a lot going on with the construction and this was the one thing that got by me. I didn't check on what I'd need for a hot tub. I just didn't know that I would need 60 amps and never thought to question it or look into it. It wasn't until the house was completed and we started looking for hot tubs that I realized this was an issue, and of course our electrician had only wired for 50 amps. It was quite a decision for us on what we should do. In the end we paid around $800 extra to get the correct wiring run, so we could have 60 amp service. He had to run it outside and up the side of our house to the roof deck. Luckily it's hard to see as the house on this side is situated very close to our neighbours, so it is not a real distraction. But still, it cost us around $800 to fix what should have been done the first time. But even with that, I'm glad now that we did it. When we're in the tub we quite often have both pumps running at the same time, and in the middle of winter, I want that heater to kick in when it needs to!
amy2421
Re: New Jacuzzi
« Reply #14 on: October 03, 2015, 05:46:53 pm »
It is hard to get everything just right on a big project. On a much smaller scale, with our backyard reno we had some specific requests for electrical runs for receptacles and landscape lighting and somehow it got lost in the shuffle. By the time our electrician was on site, it was too late for some of it because we did not have the right number of conduits or in the right places. It was a little frustrating because we thought we were pretty clear before we got started. But everything else looks beautiful so we are very happy. I am glad that with the hot tub electrical we got it done properly instead of listening to the first electrician!
Re: New Jacuzzi
