Author Topic: Identify this leak/part  (Read 1680 times)
glasshopper
« on: August 26, 2015, 10:17:37 am »
2007 Dynasty Neptune
I have 2 small leaks, both leaks are coming from inside the threads of the diverters.  It seems to pulse the leak out.  I am new to the spa scene and learning how to identify parts.  I believe these are called diverters?  I noticed there is a plastic nut threaded on to the threaded shaft.  Is there a washer or seal that has failed?  Or maybe take it apart and pipe dope it?
Can I remove the diverter from above or from underneath.  If underneath I don't think I can get a wrench on the nut because the frame is in the way....hhmmm thoughts?
Thanks.
