Author Topic: Brand new tub - how long to heat up?  (Read 7253 times)
aquaman617
« on: August 04, 2015, 08:45:50 pm »
I just took delivery on my Sundance Edison yesterday.  Wiring was done at 240V/50A.  I set the temperature to 102F at 2pm yesterday (water temp, 63F).  As of 8 pm today, the temperature has only risen from to 96F.  Aside from a few hours when either my kids or I went into the water (sometimes with the jets on), the lid has been on and the jets turned off.  Overnight, the temperature did not budge more than a degree or two (lid was on overnight).
Am I doing something wrong?
kingdarb
Re: Brand new tub - how long to heat up?
« Reply #1 on: August 05, 2015, 07:31:29 am »
If the settings are all correct then it will reach its setpoint.
I only have experience with my own tub, which seems to take around ten hours to get from hose water temperature to 102F.
Water Boy
« Reply #2 on: August 05, 2015, 10:11:40 am »
That seems like a really long time to me. That spa should have been to 102 degrees in about 8-10 hours max. It sounds like in your situation, after 30 hours it still was only up to 96 degrees. I would call your dealer and have them check that out. If I understood your time frames right, then imo it isn't heating properly.
« Last Edit: August 05, 2015, 11:54:52 am by Water Boy »
Quickbeam
« Reply #3 on: August 05, 2015, 11:36:59 am »
That seems like a really long time to me. That spa should have been to 102 degrees in about 8-10 hours max. It sounds like in your situation, after 30 hours it still was only up to 102 degrees. I would call your dealer and have them check that out. If I understood your time frames right, then imo it isn't heating properly.
+1 There is something wrong if it's taking that long to get up to temperature.
« Reply #4 on: August 05, 2015, 12:08:47 pm »
I've owned 2 tubs. The larger one heated at about 4 degrees and hour.  The newer tub, which is a smaller Sundance heats closer to 8 degrees and hour.
aquaman617
« Reply #5 on: August 09, 2015, 06:22:01 am »
My dealer sent out a repair guy this past week.  Loose wire (or something) to the heater was the culprit.  Up and running and enjoying every minute of it!
Quickbeam
« Reply #6 on: August 09, 2015, 05:08:06 pm »
O.K., that makes sense. Figured there had to be something wrong. Glad you got it fixed and are enjoying your spa!
