Author Topic: Want to Add Ozonator to Bullfrog - Plug Type?  (Read 4202 times)
kingdarb
« on: July 26, 2015, 08:48:45 pm »
Hey folks.  I am thinking of adding a Del Spa ozonator to my bullfrog R6 tub.  I am likely going to install it myself.  I have to modify my deck a little bit to create access to the control panel, so I have not been able to open it up to see what type of plug the ozonator needs to connect to.  I am hoping to order an ozonator so that the install can coincide with my next drain/refill as well as the day that I modify the deck an install a trap door.  So I was hoping that someone might know the answer as to what type of plug I would order on the ozonator (four prong/two prong/j&j,etc...) so that I can more or less do everything at once.
Thanks in advance!!
HotTubLover57
Re: Want to Add Ozonator to Bullfrog - Plug Type?
« Reply #1 on: July 27, 2015, 12:54:20 pm »
If you have a Balboa circuit board, it is likely that you need a Amp 4 connector.
kingdarb
« Reply #2 on: July 27, 2015, 06:53:54 pm »
Hey thanks for the reply.  It is a Balboa board.
HotTubLover57
« Reply #3 on: July 29, 2015, 11:16:27 am »
No prob, hope it helps!
