Author Topic: Dip switch settings - Balboa inf107  (Read 4512 times)
saskvaliant
« on: July 12, 2015, 11:08:47 am »
Can anyone help me with this one? I bought a second hand Balboa INF107 spa pack everything is working but not correctly. I have a 2 speed pump in connection 1 to run the jets and a separate circulation pump. On turning on the spa pack goes through its checks and then goes to heating but the jet pump is turning on as well as the circ pump. Currently all dip switches are set to off, I suspect I have to switch the circ pump dip switch to 'on'? any advice will be appreciated.
HotTubLover57
Re: Dip switch settings - Balboa inf107
« Reply #1 on: July 24, 2015, 06:30:17 pm »
All you need to do is determine the proper dip switch settings.
To do this, you'll need to know the chip number on the board. The chip number is an alphanumeric number that you will find printed on a white label placed on a black chip on the board itself.
Here an example of where a chip number is located: http://hot-tub-blog.typepad.com/.a/6a01a73e0f5ad5970d01bb07eecac4970d-800wi
If you reply with your chip number, I can help you determine the proper settings for your dip switch.
