Author Topic: Whats comparable to the HS Vanguard?  (Read 2794 times)
Sooner Wing
« on: May 18, 2015, 02:02:26 pm »
What’s comparable to HS Vanguard in regards to size, quality, and accessories?  I want to check out similar tubs before not sure where to start.
Re: Whats comparable to the HS Vanguard?
« Reply #1 on: May 18, 2015, 06:44:30 pm »
 Jacuzzi wise the J-470 J-365 or J-345 Bullfrog I would look at the R7 or A7   Sundance Majesta  Marquis would be another brand as well.   Suppose it would matter what's available to you.
richierich
« Reply #2 on: May 18, 2015, 07:23:05 pm »
 You can look at the tubs on the manufactures web sites. The brands Jim mentioned are all top quality. If you like what you see on the web  site go to a local dealer for a better look and arrange for a wet test for the tubs you find meet your criteria. Shopping for a hot tub can be fun as well as challenging. The internet makes it easy to compare tubs from competing brands. Good luck in your search.
Hot Spring Ace
« Reply #3 on: May 18, 2015, 10:12:43 pm »
Caldera Tahitian and Caldera Salina are a couple more that you might consider as well.
MarKee
« Reply #4 on: May 19, 2015, 02:45:46 am »
Marquis Epic, Marquis Reward, Marquis Wish.  Check those out at your local dealer
« Reply #5 on: May 19, 2015, 07:31:42 am »
As a Majesta owner and my sister being a Vanguard owner, I think that is a fair comparison.
Sooner Wing
« Reply #6 on: May 19, 2015, 09:26:38 am »
Thanks guys, this gives me a good place to start researching.  Surprisingly, I don't believe there is a Marquis dealer that close to Oklahoma City.  There are Jacuzzi, Sundance, and Bullfrog dealers so I will check the suggested models out.
« Reply #7 on: May 19, 2015, 10:52:45 am »
Wet test them!!!
« Reply #8 on: May 19, 2015, 01:03:40 pm »
We will welcome hearing your thoughts.  There is no right and wrong for everyone.
