Author Topic: In ground spas  (Read 3362 times)
jumprightin
In ground spas
« on: July 10, 2004, 04:59:14 pm »
My husband and I just started our spa search and we were interested in the inground versions.  What types of things should we look for, any information on brands that you recommend or avoid would be greatly helpful. ::)
In ground spas
SunshyneGyrl
Re: In ground spas
« Reply #1 on: July 10, 2004, 08:34:16 pm »
I have an Optima (Sundance) and I know that they make a bunch of inground spas.  dont know too much about them.  check with your dealer
Electro
Re: In ground spas
« Reply #2 on: July 11, 2004, 02:43:08 pm »
jumprightin,
In-ground spas are not a good choice, because of maintenance and repair.  Unless the in-ground spa is designed to expose all sides with access or you have an elevator underneath that can lift the whole thing, in-ground spas are trouble.
Leaks are a fact of life.  Consider how you'll get access to the plumbing all around the spa.
ZzTop
  • Beachcomber 550x owner
Re: In ground spas
« Reply #3 on: July 11, 2004, 06:37:59 pm »
Have a look at  www.bradfordproducts.com
Very unique Stainless steel and ceramic tile in ground  Spas
« Last Edit: July 11, 2004, 06:43:53 pm by ZzTop »
Re: In ground spas
