Original
Size of wire for my new hot tub question
Pages: [
Topic: Size of wire for my new hot tub question (Read 2482 times)
ralphw
Junior Member
on:
February 17, 2015, 08:06:13 pm »
I am replacing my hot tub which was using a 50amp circuit breaker to my Artesian Santa Cruz Spa. The current wire is 6awg and is being run for approx 36 feet. Is this sufficient, and all I need to do is change out the circuit breaker??
on:
Ultimate Member
If it Ain't Broke
Re: Size of wire for my new hot tub question
Reply #1 on:
February 17, 2015, 10:39:56 pm »
Depends on your local codes but I think it's overkill in the NEC book.
flava flav
Junior Member
Reply #2 on:
February 18, 2015, 02:06:45 pm »
Talk to an electrician and read up on NEC 2011. Double and triple check that it's 6 gage. Also you need to check the amp draw from the tub. You can put an 60A breaker on 6 gage
copper
romex wire. Although romex 6 gage is rated for 55 amp NEC allows to round up on the breaker size. If it's THHN wire than its rated for 65A.
http://www.cerrowire.com/ampacity-charts
I'm sure the tub will draw less than 55 amp. As long as it does then it sounds like a breaker change to 60A will only be required while using the existing wire. Good luck and be safe boyeee.
Reply #2 on:
Pages: [
Original
