Author Topic: Cloudy Water  (Read 2452 times)
bothfly
Cloudy Water
« on: February 07, 2015, 11:59:21 am »
So new Spa, just started using the Spa Frog. Was in the tub the other night. Today the water is cloudy. Spa test strips show water is good, maybe a tad low on Bromine, which I just raised on the Spa Frog.
So do I need to add shock to clear the water or a water clearer?
There is one on Amazon called Leisure Time that has both.
What do you add to clear your water?
Cloudy Water
Kev B
Re: Cloudy Water
« Reply #1 on: February 09, 2015, 11:22:52 am »
The frog system requires shocking every week or "as needed" I would shock it more frequently and keep the filters clean before I started moving into other products. Also, I always assume you have the ph and alkalinity perfectly balanced with an ideal calcium level.
Re: Cloudy Water
