Author Topic: Used Tub Setup  (Read 2198 times)
UnHombre
Used Tub Setup
« on: December 17, 2014, 10:33:59 am »
I recently purchased a used tub from a friend. The tub was drained, cleaned, filters washed, and the tub was placed in storage by the dealer. During my setup, I noticed that the clear water lines had some scaling coming lose inside the tubes. I would like to know if I should replace the filters and flush the system before using it. Any other tips on setting up/getting this tub running will greatly be appreciated.
Used Tub Setup
Kev B
Re: Used Tub Setup
« Reply #1 on: December 17, 2014, 11:00:51 am »
 Best thing is to fill it, add a pipe cleaner such as swirl away and run the heck out of it. Make sure all jets are going and leave filters out. Run it for a day, drain, clean refill and put in filters.
UnHombre
Re: Used Tub Setup
« Reply #2 on: December 17, 2014, 11:08:14 am »
New filters?
Re: Used Tub Setup
« Reply #3 on: December 17, 2014, 05:49:16 pm »
Re: Used Tub Setup
