Author Topic: Jacuzzi J-355 vs Sundance Cameo vs HotSpring Envoy  (Read 4401 times)
Sorrentino100
« on: December 13, 2014, 12:40:54 pm »
I'm considering these three tubs: Jacuzzi J-355, Sundance Cameo and HotSpring Envoy.
I'd appreciate comments regarding the pros, cons and experiences with these tubs and how they compare. Which would you buy? And why?
« Last Edit: December 13, 2014, 05:30:20 pm by Sorrentino100 »
Re: Jacuzzi J-355 vs Sundance Optima vs HotSpring Envoy
« Reply #1 on: December 13, 2014, 12:59:27 pm »
All great choices.  Out of those I like the OPtima the best.  It's probably the most expensive as well.  Have you wet tested them?  I would probably make my decision based on that
TwinCitiesHotSpring
« Reply #2 on: December 13, 2014, 02:29:59 pm »
Personally the Envoy/Aria are my favorite spas so my biased opinion may not count much  :P, but I will say if you feel more comfortable with the local Hot Spring dealer I'd check out the 'Pulse' model as another potential option....it is very close to the Optima as far as specs go (size, jet count, # of pumps, layout, etc.) see it here: http://www.hotspring.com/shop-hot-tub-models/limelight/7-person-large-hot-tub-pulse
Also as most people will ask here: have you tested any of them? have you received quotes on all of them, or is pricing not really an issue? have you been in to scope out the local dealers, do any of them seem much more competent than the next?
Sorrentino100
Re: Jacuzzi J-355 vs Sundance Cameo vs HotSpring Envoy
« Reply #3 on: December 13, 2014, 05:29:47 pm »
Sorry, meant the Sundance Cameo. Looking for a hot tub with a lounger.
« Reply #4 on: December 13, 2014, 09:34:03 pm »
 I was going to say things didn't match up, all good choices.   Defiantly wet test to decide which works best for you.
« Reply #5 on: December 14, 2014, 02:18:57 pm »
Hot Spring Aria also?
« Reply #6 on: December 14, 2014, 02:34:30 pm »
All great choices.  You can't go wrong with any of them, if they meet your needs.  As stated above, if you can wet test, let that be your deciding factor.  Forget all of the sales BS.  You've picked 3 brands that are in almost everyone's top 5 to 7 manufacturers.
