Author Topic: More Older Sundance Spa Newbie Questions  (Read 2580 times)
Schergz
« on: December 13, 2014, 01:33:00 am »
 1990 Sundance Serenna . Have some questions if anyone can help:
1.)  I purchased a colored lense like this . Do I need to drain the spa before changing? I thought it would just snap over the existing fixture, but no. It seems that I need to unscrew the chrome bezel around the light fixture first. then swap with the clear lense?
2.) I've noticed that the large whirlpool jet/diverter control, when turned all the way in either direction (whirlpool or therapy jets) still allows some flow to the other set of jets which it should isolate. Also, I just added an ozone manifold into the 1.5" plumbing and noticed that I can see the ozone bubbles coming out around the perimeter of the whirlpool jet control when it set to the therapy jets. I'll try to post a youtube video so this makes more sense.http://youtu.be/b3iyHWc-iLI Is this maybe just a bad o ring or something? I've searched youtube etc. but am unable to find any info about troubleshooting rebuilding / repair etc. Any info would be greatly appreciated.
3.) Lastly,there doesn't seem to be any noticeable difference with the air control in the open or closed [/url]position. Should I be noticing a big difference? Any Idea how to repair or what to check for?
Re: More Older Sundance Spa Newbie Questions
« Reply #1 on: December 13, 2014, 11:39:10 am »
That particular light lens just snaps on (no draining required). If it doesn't, and/or you think you need to drain to install it, it's not the correct part for you type of light.
« Reply #2 on: December 13, 2014, 09:35:12 pm »
 Why not order an after market multi colored LED light off Ebay, it will plug right in.
  There are many others this was just a quick search..
 http://www.ebay.com/itm/Hot-Tub-Spa-LED-Light-Cluster-Ultra-Bright-/221630622686?pt=LH_DefaultDomain_0&hash=item339a36ebde
« Last Edit: December 13, 2014, 09:37:21 pm by Jacuzzi Jim »
