Author Topic: Changing filter cycles on Gatsby hot tub  (Read 1842 times)
tomasaur
« on: October 09, 2014, 09:28:03 pm »
I bought a used Gatsby tub a little while ago.  It seems that the filter cycle is always on, as there's always a pump running (not a big jet pump, it's the same one that runs water through the heater).  I found a users manual online http://jacuzzichino.com/manuals/Gatsby.pdf and it appears that you should be able to change the filtration cycle by pressing the light button for 5 sec and then scrolling through options that appear on the lcd screen.  This doesn't work on my tub, pressing any button for 5 seconds or more has the same effect as a momentary push.
Any ideas out there?
Thanks in advance,
Tom
Re: Changing filter cycles on Gatsby hot tub
« Reply #1 on: October 10, 2014, 09:45:57 am »
 Try pushing light btn then a temp btn. Worth a try..
