Author Topic: Rookie mistake  (Read 1714 times)
Budule
Rookie mistake
« on: August 30, 2014, 09:47:58 am »
ok , feeling a little stupid here , anyway 10 day old spa , Leisure time chemicals (chlorine)....all three used the tub last nite and as per instructions when we got out I put in the "Spa 56 " ....it was a little low before so I may have put in a "little extra".....checked it this morning and it was "very low" .....huh? .....well , ill fix it.....more is better right ?.......problem was I had just got new test strips and they were different from the old ones......first pad was BROMINE , and that's what was "very low".....now my chlorine is off the charts......will that come down by itself (run jets and air? ) or do I dump it......water is cheap here in West Virginia......
Rookie mistake
clovett
Re: Rookie mistake
« Reply #1 on: August 30, 2014, 09:58:20 am »
I'm fairly new also but maybe you should read your level and figure out how much water to dump out?  Like if it's a third high dump out 1/3 of the water?  That is what I would try but for all I know you should dump the batch.
Re: Rookie mistake
