Author Topic: HotSpring Sovereign vs HotSpring Relay  (Read 8814 times)
Quickbeam
Re: HotSpring Sovereign vs HotSpring Relay
« Reply #15 on: August 20, 2014, 06:17:58 pm »
I don’t doubt for a minute that you’ve had an abysmal experience. What I’m saying however, is that you are by far the exception, not the rule. You will find most Hotspring owners on this and other forums are very satisfied with their products. Hotspring has a good reputation and I don’t think someone should be influenced to not purchase a Hotspring product because of “the exception”. Now if Hotspring had wide spread customer complaints, that would be a different matter. But the fact is, they don’t - most Hotspring customers are satisfied.
Have you noticed how when someone comes onto this forum to point out the bad quality, design and pricing they're shouted down by the zealots?
"Your experience is incorrect because mine hasn't failed yet!"  (Oh, and you're also probably not as smart as someone whose spa hasn't failed.)
Or the latest comments from today: "It's time to censor the guy who's having the bad experience."
I'm not shouting you down nor am I a zealot. I don't even own a Hotspring. And I never once suggested you should be censored. In fact I said I didn't doubt you had a bad experience. What I said, and I stand by, is that others should not make buying decisions based on one person having a bad experience.
NZArtist
« Reply #16 on: August 20, 2014, 06:39:53 pm »
Right, but if other people are shouting down someone who's sharing their negative experiences you're not going to see many people posting about negative experiences.
So if someone is persisting here and posting about obvious quality issues with the spa, whether it's unique to their experience or not, you absolutely should be weighing their experience in making a decision.
Other people have had bad experiences with the ACE system.  I'm apparently a fool for buying it - I get that.  So don't buy an ACE system.
Other people on this forum are as incredulous as I that the heater is a paltry 1500 watts.  So don't buy a Hotspring spa in New Zealand.
The spa service person tells me the pump seal replacement is a common problem (but still it must be my fault) - other spas I've owned haven't had that common problem (and I haven't caused it on other spas...) so I don't know what your take on that is.
The cover straps ripped.  They are thin vinyl.  A nylon webbing strap would never rip.  It's a poor manufacturing decision on behalf of the spa manufacturer.
None of these problems apparently are unique to me.  It's not just my one bad spa.
If it was just the one or two problems I wouldn't even care.  Every product has design deficiencies.
But come on!  This Hotspring spa is poorly designed, and hideously overpriced for the bad quality.
It's *supposed* to be the BMW of spas.  But if you slap a BMW logo on a Lada and charge a BMW price,  regardless of your marketing expertise (where did they find a female voice actor for their robo-phones who can make 'Hotspring Spa' sound like something said during orgasm??) it's still a Lada and you're going to have a Lada experience.
Just so you know... I have a friend with a Lada and he loves it but I'm never going to buy one ever.
Quickbeam
« Reply #17 on: August 20, 2014, 10:21:20 pm »
I would absolutely agree with you on the Ace System. You will find people on this forum who defend it, but I’ve seen reports from lots and lots of others who have had major problems with it. Personally, I would not go near it.
As for the heater, once again we agree. I think it’s crazy that such a small heater is put in the spa. Having said that however, when I look on our North American Hotspring website, it lists the heater as 4000 watts (http://www.hotspring.com/shop-hot-tub-models/highlife/7-person-large-hot-tubs-grandee). So, as you said, this must be a problem in New Zealand.
As for the pump seal replacement and vinyl straps, I don’t know anything about those. Not sure if they are a problem just in New Zealand or in other areas as well? I certainly don’t remember seeing those complaints on this forum, so I’m going to make the assumption that this may also be a problem just in New Zealand.
So, IF my assumption is correct, then three of the four problems you list are centered in New Zealand. Why then would someone in North America take your experience into account when buying their spa?
As an aside, I do think it is valuable when people post problems with their spas. It does help educate us and help us to know what to look for. But you didn’t just report what the problems were. You came out in a pretty aggressive manner and advised people not to buy the spa. I just personally think you went over the line - you were no longer informing us as to what the problems were and advising us what to look out for - it seems to me at least that you are trying to carry out a personal vendetta against HotSpring.
NZArtist
« Reply #18 on: August 20, 2014, 10:37:21 pm »
I'm going to run with: The poor design, bad pumps, bad chlorinator, cheap cover straps, overpricing and high maintenance price are universal problems.
I'll grant you that the 1.5 kW pump is not a US problem.
That's just the cream on the cake.
Y'know it's possible that underpowered heater is the cause of some of the other problems.  The heater turns off when any of the jet pumps are run. (You know, that moment when you need the most heat because the cold air from the jets is cooling the water fastest?  Yeah, that's when the heater turns off).  Because the water cools so very quickly when any of the jets are run we almost never run the jets.  The exception is after a few people have been using the spa I'll run the cleaning cycle as soon as they get out of the spa.
So because the jets are rarely run the filtration is all happening through the cycle pump.  The cycle pump has one filter and it's the one with the ACE chlorinator. So it's likely to be the filter most quickly getting clogged and preventing proper operation of the ACE system.  (Why yes, I do clean the filters out monthly and rotate them).
I don't know.  It's still the worst spa I've owned.  Okay, I'll stop short of advising people in the US not to buy it.  Go ahead - it's your money, time, and stress levels.
Certainly if you live in New Zealand (or any other country where the spa heater is around 1.5kW) don't touch these things with a barge pole - you'll end up hating it.
« Last Edit: August 20, 2014, 10:40:55 pm by NZArtist »
kporter
« Reply #19 on: August 21, 2014, 03:37:22 pm »
NZartist
You hijacks other peoples posts. That is just bad form.
You want people to know you are unhappy, you want people to know about the terrible product you purchased and the terrible after service you have received. You have done it. If a new forum member comes on and asks for people personal experiences with Hotsprings Spas you have got your outlet. Stop hijacking other posts so you can vent. You come across like a raging teenager.
Porter
mjb1967
« Reply #20 on: August 22, 2014, 05:55:37 pm »
regarding the price, here is what our local dealer quoted me:
I can do $6,200 on a 2014 Relay.
Price includes everything you need!
he also said that if they had one in stock already, he'd drop it to $5900
