Author Topic: breaker keeps jumping  (Read 15869 times)
bandito
« on: August 17, 2014, 12:24:16 am »
The GFI breaker has  recently has been jumping lately.  Whenever the heater kicks in a few minutes later the breaker jumps and one if the leads coming from the breaker gets hot and smokes a little. Here is a picture of the lead .  I tested the breaker with a volt meter.  117 volts from each hot lead to ground and 234 from hot lead to hot lead so it appears to be working properly. I checked all the wiring for shorts and no luck.  I also poked around the wiring looking for one the may be hot which was not the case. I even pulled the filter figuring that maybe the pump was working to hard. Any ideas for trouble shooting?
bandito
Re: breaker keeps jumping
« Reply #1 on: August 22, 2014, 10:29:29 pm »
So I replaced the breaker with a 40amp breaker as specified in the manual. Ran it for about 6 hours with no problems or any wires getting hot.
clovett
« Reply #2 on: August 28, 2014, 08:11:41 am »
If you replaced it with a 40 amp breaker what size GFI breaker were you using before?
