Author Topic: 3 flashing dots on a barefoot spa  (Read 3669 times)
kittyhawk32
« on: July 15, 2014, 09:23:53 am »
I just got a Barefoot MR77 spa. When I go to set up the temp 3 flashing dots appear on the control panel.  I'm at a lost of what or how to troubleshoot it. Need help.thanks!!!!
Re: 3 flashing dots on a barefoot spa
« Reply #1 on: July 15, 2014, 11:17:32 am »
3 dot's is usually some kind of flow error..
kittyhawk32
« Reply #2 on: July 15, 2014, 01:32:45 pm »
I have found a small  leak under the tub. Would this cause a flow problem? I have bleed the air out of the 2 pumps and it seems that the water is flow good. Where would I start to look for a flow problem?
« Reply #3 on: July 15, 2014, 02:50:21 pm »
 A leak would have nothing to do with a flow issue or the 3 dots.     Might be a bad pressure switch or a dirty filter.   Remove the filter, shut the spa off for 15 min.   Turn it back on without the filter in and see if the dots go away.  If they do then put the filter back in slowly, if the dots come back it's probably a bad filter.  If the dots are still there after turning it back on without the filter in you have something else going on like a air lock, bad pressure switch or a bad board maybe.
