Author Topic: Question re Balancing Water  (Read 12694 times)
Quickbeam
Re: Question re Balancing Water
« Reply #15 on: July 13, 2014, 12:45:55 pm »
No, I'm talking about having the jets on full with the air control to the jets turned on. Waterfall also going.
Quickbeam
« Reply #16 on: July 13, 2014, 12:47:43 pm »
As for hydrogen peroxide wear on hot tub components, see this post, this post, and these posts.  Also, this manual ("Please avoid using any spa chemicals that contain Hydrogen Peroxide. Hydrogen Peroxide based spa chemicals have been found to react adversely with the materials used to produce these components.") and this manual ("Alps Spas strongly discourages the use of chemicals that contain Hydrogen Peroxide. Hydrogen peroxide will eventually cause the light body and lenses (used on all spas) to become brittle and crack.").
glad I read those , but I don't think I was going to try it anyway ( no way I am now ) but that was my guys take on it mostly , makes things "brittle" over time (who needs that ?) hard on seals and the problems wouldn't show up until the warranty period was over ......again , I don't know if its true or not but im not chancing it.....maybe people that ARE using it can update on it after at least 3 to 5 years of use and see if there were any side effects ?
As I said we are using hydrogen peroxide and will continue to do so, although I must admit I’m not thrilled with the information that Chemgeek provided. I really don’t need those kind of problems in my tub. Having said all that, the main reason we started using hydrogen peroxide is that my wife has some pretty serious chemical sensitivities and we just didn’t want to chance either chlorine or bromine. After having used it for a while now, we love it. No chemical smell, no dry skin, skin feels almost smooth or moisturized after a soak. For us so far, it is a great alternative.
If I remember I will keep you updated on any significant equipment problems that are related to the use of the hydrogen peroxide. We do have a friend who has been using it for some time now without any problems. Not sure exactly how long they have used it, but I will check with her and report back.
One other thing that may come into this. It seems to me that there is a kind of trend with people who use hydrogen peroxide that they do nothing else to take care of their water. I’ve seen a blog re hydrogen peroxide in hot tubs and from what I could tell, there was no other water maintenance being employed. I know our friend who uses it does nothing  else to take care of her water. I’m wondering if this is a trend with hydrogen peroxide users, if this could be one of the factors contributing to equipment failure???
clover
« Reply #17 on: July 13, 2014, 02:45:11 pm »
.....I know that my TA is low, but it needs to be at 30 for my PH to stay stable during aeration. My TA was also at 30 during my initial fill.....
.....glad I read those , but I don't think I was going to try it anyway ( no way I am now ) but that was my guys take on it mostly , makes things "brittle" over time (who needs that ?) hard on seals and the problems wouldn't show up until the warranty period was over ......again , I don't know if its true or not but im not chancing it.....maybe people that ARE using it can update on it after at least 3 to 5 years of use and see if there were any side effects ?
.....As I said we are using hydrogen peroxide.... and will continue to do so.....the main reason we started using hydrogen peroxide is that my wife has some pretty serious chemical sensitivities and we just didn’t want to chance either chlorine or bromine. After having used it for a while now, we love it. No chemical smell, no dry skin, skin feels almost smooth or moisturized after a soak. For us so far, it is a great alternative.
Quickbeam, There are always 2 side to any coin, and as for consequences, only time will tell the truth.
What I don't understand is why you feel compelled to keep your alkalinity low when it needs to be in the 80-120 range, your pH is elevated, and yet you're willing to take it higher to 7.8.....after you made a reference in a recent post, "no chemical smell, no dry skin, skin feels almost smooth or moisturized", which means you are familiar with these conditions.  Your skin is pH neutral in the 7.2 to 7.6 range, higher, or lower, will give you dry skin, and females will avoid it.  As for alkalinity being out of range, it needs to be adjusted first, as pH will not stabilize and stay where it belongs until alkalinity is in the proper range.  Adjust your alkalinity first, THEN, adjust pH up or down as necessary, and it will stabilize.
When you smell, ding, ding, ding, your "smeller tester" is going off, indicating attention is needed.  I know that time has past, but if your pH is not 7.2 to 7.6, and your alkalinity is not in the 80 - 120 range, you will have water problems, and gas off the water (the smell).
Unless the water is right on, the ladies loose interest, us guy's, what do we care, we will sit in battery acid as long as we have a beer, but ladies are different.  We are dealing with water chemistry here and everything is said to be able to provide results, but as you can see, there are 2 sides to every coin.
Have you considered using ozone on your spa?
Budule
« Reply #18 on: July 13, 2014, 02:53:55 pm »
[/b]
There IS truth on the internet !......can I use that as my sig?
clover
« Reply #19 on: July 13, 2014, 03:28:11 pm »
[/b]
I would be glad to share it with you, I've got many more. ;)
Quickbeam
« Reply #20 on: July 13, 2014, 05:41:24 pm »
Sorry Clover, I’m not really sure I understand your post. I don’t feel compelled to keep my TA low. My PH will not remain stable unless my TA is low. If my TA is anything above 30 my PH shoots up when I aerate the tub.
As for adjusting the alkalinity first, that is exactly what I’m doing. The correct procedure, as I understand it, is to add acid (in my case I’m using dry acid), then aerate the tub, and check your readings. The more dry acid you add, the lower the TA. My problem is that when I aerate the tub with a TA above 30, my PH shoots up. There are others on this board who have had similar experiences.
Once my TA is at 30, the PH becomes stable. I could at this point add some borax to slightly increase my PH, while leaving the TA at 30. This was my original question as to whether or not I should do this, so my water would be in balance according to the Saturation Index. With my numbers, if my PH was 7.8, I would be in balance according to the Saturation Index. Chemgeek has advised that I don’t need to bother adjusting my PH, so for now I’ll leave the PH at 7.6.
As for a “smell test”, my water has never had any kind of foreign smell and has always been crystal clear. I’m a new tub owner, but at least so far my water has been excellent. The only problem I’ve had is that the PH will not stabilize until my TA is very low, which once again I know others on this board have experienced.
chem geek
« Reply #21 on: July 13, 2014, 06:06:08 pm »
There is so much that is wrong here I hardly know where to begin.  First of all, skin is NOT pH neutral in the 7.2 to 7.6 range.  The pH of skin is normally acidic in the 5.4 to 5.9 (or 4.5 to 6.0) range (see this paper and this paper).  Perhaps you are thinking of the pH of human tears which average 7.50 in this paper or 7.0 in this paper.
It is absolutely positively not true that you set your TA to a range such as 80-120 ppm and that the pH will then stabilize anywhere near the range of 7.2 to 7.6 that you desire.  This will only occur if you are using net acidic chemicals in the spa such as Dichlor for chlorine or bromine tabs for bromine or MPS non-chlorine shock and even then it depends on how much aeration there is in the spa.  If instead you are using net pH neutral chemicals (which includes the pH that results from their usage/consumption), then the pH will rise from the high TA since the water is over-carbonated which increases carbon dioxide outgassing (the TA does not change from such outgassing; the TA only drops when you later add acid to lower the pH).  Increased aeration of the spa water will increase the rate of carbon dioxide outgassing and therefore the rate of pH rise.  The amount of over-carbonation of water with respect to air is shown in this chart.  TA is mostly a measure of bicarbonate in the water and that is in equilibrium with carbon dioxide in the water.  The equilibrium pH at various carbonate alkalinity levels (same as TA if there is no CYA nor borates in the water) is as follows where I also show the pH where water has 2x the amount of carbon dioxide compared to air (at 100ºF water temp):
Carb.Alk. . pHeq . pH2x
.... 10 ...... 7.55 ... 7.25
.... 20 ...... 7.84 ... 7.55
.... 30 ...... 8.02 ... 7.72
.... 40 ...... 8.14 ... 7.85
.... 50 ...... 8.23 ... 7.94
.... 60 ...... 8.30 ... 8.02
.... 70 ...... 8.37 ... 8.08
.... 80 ...... 8.42 ... 8.14
.. 100 ...... 8.51 ... 8.23
.. 120 ...... 8.58 ... 8.30
.. 140 ...... 8.64 ... 8.36
So with lots and lots of aeration to increase the surface area between air and water to drive out carbon dioxide faster, your 80 ppm TA would have the pH rise and only reach equilibrium at 8.42.  In practice, the rate of pH rise slows down considerably as one approaches equilibrium but even 2x out of equilibrium (i.e. twice as much carbon dioxide in the water as there would be with equilibrium in the air) is a pH of 8.14.  You can see that at a TA of 30 ppm the equilibrium pH is 8.02 with a 2x equilibrium pH of 7.72.  This is why having a TA of 30 works much better for Quickbeam and indeed in general those using other pH neutral methods such as after switching to bleach when using Dichlor-then-bleach should not have their TA be higher than 50 ppm.
Acrylic spas with no exposed plaster or grout do not need to be saturated with calcium carbonate which is the primary reason for having higher TA and CH.  The main reason for the 80-120 ppm TA standard recommendation (which is really more for pools than for spas) is that one normally uses net acidic chemicals so having the carbon dioxide outgassing helps to compensate for that to stabilize the pH.  As for pH buffering itself to minimize the swing in pH from any chemical sources, one can use additional non-carbonate pH buffers when their TA is low such as using 50 ppm Borates (some people use phosphate buffers as "pH lock", but that precipitates calcium so can be messy initially).
« Last Edit: July 13, 2014, 07:00:39 pm by chem geek »
Quickbeam
« Reply #22 on: July 13, 2014, 06:15:29 pm »
Thanks Chemgeek,
For another in depth explanation. I do however have a couple of novice questions for you. I have been balancing my water before adding my sanitizer. Is this the correct method, or should I start by adding the sanitizer, or does it matter? And as for adding the boric acid, I have been adding this after my TA is down to 30 and my PH has stabilized. I'm assuming this is the correct sequence?
chem geek
« Reply #23 on: July 13, 2014, 06:58:48 pm »
In your situation since hydrogen peroxide addition is essentially pH neutral, you can balance before adding the hydrogen peroxide.  Obviously you don't want to wait too long (many hours) since you don't want bacteria to grow when there is no disinfectant but odds are your tap water has a disinfectant in it already.
Yes, you usually want to add the boric acid after lowering the TA.  If you do this the other way around, then this makes it harder to know the TA lowering process is working because you won't see the pH rise as quickly as an indicator to you for when to add more acid.  Also, when you are at the end of the process with the TA where you want, you then want to aerate to get the pH up but that will also take longer when the borates are present.  It's not a disaster to do it this way, but it can be more confusing or frustrating.
« Last Edit: July 13, 2014, 07:01:35 pm by chem geek »
Quickbeam
« Reply #24 on: July 13, 2014, 07:45:28 pm »
Makes sense! Thanks Chemgeek.
