My guess is a clog on the line leading from the ozonator to the venturi injector, be careful though, a byproduct of the ozone reacting with moisture in the air over time in the tube is nitric acid, so handle with care, and don't assume the clear fluid in the ozonator tube is water. As has been mentioned this is a completely separate issue from telling if the Ozonator is producing ozone, for that you need an ozone tester (glass tube you break and suck the output through to test for ozone, they cost about $12-$15 each), or if it is more than 3-4 years old you can just assume it is dead if it is not one of the new types with a built in indicator. (Note you can buy Del brand ozonators that much of the industry uses for about $100, if you do you may have to replace the venturi ($20), or adapt it from a screw on connector to a hose barb style tubing connector ($3 plumbing fitting))
