Author Topic: indoor spa  (Read 4278 times)
dmh807
indoor spa
« on: June 23, 2004, 01:58:10 pm »
We're getting a hot tub and will be locating it in our new sunroom.  Any suggestions for installing it and upkeep inside?  Anyone have any problems doing this?
indoor spa
drzonker
Re: indoor spa
« Reply #1 on: June 25, 2004, 09:31:54 pm »
my freind's freind this this and had a very bad moisture probel and rotting wood --this was heard second hand
stuart
Re: indoor spa
« Reply #2 on: June 25, 2004, 10:23:21 pm »
Ventilation is very important! The only cases of respitory problems (i.e. hottub lung) that I have ever heard of are from indoor spas!
Roborph
Re: indoor spa
« Reply #3 on: June 26, 2004, 09:55:53 pm »
 Someone had a picture of their spa in a sunroom like you're speaking of on this forum...Can't remember who but was only 1 or 2 weeks ago....Maybe he/she can help
saz
Re: indoor spa
« Reply #4 on: June 27, 2004, 01:38:00 pm »
just a question, but why are you putting it in your sunlounge, and not outside?
« Last Edit: June 27, 2004, 01:38:19 pm by saz »
doodoo
Re: indoor spa
« Reply #5 on: June 28, 2004, 09:14:44 am »
http://home.comcast.net/~autoplay/100_0681.JPG
Autoplay put up a post with a pic of an indoor set up on June 1st.  Just ensure that you get proper ventilation that is designed for the volume of space that you are going to have. If the room is attached to the main living  (house) ara then you must also ensure that the two areas are kept seperate. A hot tub like anything else containing water produces a lot of mopisture. Unless that is well designed and built you have the potential to produce significant indoor air quality problems.
dmh807
Re: indoor spa
« Reply #6 on: June 28, 2004, 09:46:17 am »
We designed the sunroom to include the hot tub.  It is a new construction and the contractor made provisions for the moisture.  Big exhaust fan, screened windows and materials designed for a moist environment.   I just didn't know if anyone else had done this.  Thanks for the  help in advance.
saz
Re: indoor spa
« Reply #7 on: June 28, 2004, 11:34:01 am »
well it sounds as though you've had this professionally planned out, and your contractor is aware of any moisture issues. I dont think you should have a problem.
saz
« Last Edit: June 28, 2004, 11:35:10 am by saz »
Re: indoor spa
