Author Topic: Dynasty hot tub leak  (Read 3946 times)
caddgod1
« on: May 17, 2014, 12:33:47 pm »
I have a leak in our dynasty spa. The water drains to the (3) drains in the bottom of the spa. I am assuming the leak is located there. I have removed the covers on the drains . The seals or gaskets appear to be old and corroded. How do I replace them.
Bob
clover
Re: Dynasty hot tub leak
« Reply #1 on: May 17, 2014, 01:25:55 pm »
Surgery.  You will need to put the spa and edge and enter into the base.  If they are leaking at the plumbing connection, there would be evidence of the leak at the fittings.  Because the drains are connected to the pumps, are you sure the orgin of the water loss is not in the EQ area.  You say it drains down to the level of the suction fittings.  Do you have any indications of water backside, left side, right side base, or in the EQ area?
caddgod1
« Reply #2 on: May 17, 2014, 01:50:53 pm »
I see a water trail coming from the middle area under the hot tub.
