Author Topic: 2004 580 Beachcomber  (Read 2679 times)
nicker22
« on: April 22, 2014, 11:51:09 am »
hi there, I was wondering if anyone could tell me what is involved in replacing a return flow sensor.  I have a line on a 2004 Beachcomber 580 tub that I can get a super deal on.  The tub needs a few jets replaced and the flow valve replaced.  The physically shape is amazing, was located under a covered area so the cabinet stairs are in excelent shape as is the shell.
thanks in advance.
Re: 2004 580 Beachcomber
« Reply #1 on: April 22, 2014, 12:04:04 pm »
  It's probably pretty standard, and easy to change out, but you need to find out if it's a pressure switch or a flow switch.
Do you know if it has the small circulating pump or just uses the main 2 spd pump.   I don't know Beachcomber all that well maybe Tman or others will chime in..
« Reply #2 on: April 22, 2014, 07:38:13 pm »
In 04 I think they used what they called the hush pump for circulation. A bit bigger than a standard circ pump. Fed more jets. Could be simple if it's just the flow sensor. Located just down stream from the heater. Where's our Beach guy? Been a while since I seen one. They have a beach repair guy around here pretty much covers all of them.
