Author Topic: 2001 Sundance Cameo 850, Pump #2 won't stop running  (Read 2045 times)
Sundance01
« on: April 14, 2014, 04:29:53 pm »
Have a 2001 Cameo 850, and noticed that a pump was running continuously.  Investigation showed that pump #2 was running.  I unplugged  the wires to pump #2 and it shut down.  The console continues to indicate (the symbol on the right side of the pump icons)  that pump #2 is running.  All other stuff runs okay.
Any thoughts.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: 2001 Sundance Cameo 850, Pump #2 won't stop running
« Reply #1 on: April 21, 2014, 10:58:57 am »
If there is an indicator telling you that the pump is running, and the indicator is solid and not flashing, that means that one of the control panels is telling the motor to stay on.  Disconnect the remote panel and see if that fixes the issue.  If it doesn't, you will need to replace your main control panel.
