Author Topic: Pump fail  (Read 2926 times)
fishman1707
Pump fail
« on: January 03, 2014, 02:42:44 am »
Hello all,
    I have a 2008 hot spot hit tub by hot springs. It has a 2 stage pump for the water jets. They are low speed running half of the jets, hi speed running half of the jets, hi speed running all the jets and hi speed running just the other half if the jets. The problem I'm having is the hi speed setting for the first set of her dose not work. When I try to turn that mode on it make and electrical sound like it is trying to turn on but nothing happens.  On the control panel the are 6 lines as an error code. I have tried turning off all the electric to the hot tub in an effort to reset it and I also drained it and started from scratch. Any suggestions? Any one know of a rest button maybe?
Pump fail
fishman1707
Re: Pump fail
« Reply #1 on: January 03, 2014, 03:05:43 am »
I believe I have 2 pumps. The one I'm having trouble with is the 2 stage pump one.
Re: Pump fail
