Author Topic: Installing a new in.k600 controller  (Read 2303 times)
Bill.Thurston
« on: December 16, 2013, 01:35:30 pm »
Old unit still works but display is distorted and hard to read.
Plug new unit in same place as old unit and nothing shows on the screen.
Pressed "0n/off" switch with no results.
Is the new unit bad? Is there an installation guide?
If I had a display, I could surely set it up correctly.
Help please!!
Re: Installing a new in.k600 controller
« Reply #1 on: December 16, 2013, 06:32:38 pm »
Hmmmmmmm the new controller is compatible I am assuming. Make sure all the contacts in the plug and on the cable are clean and not bent.
Ryan VSO
« Reply #2 on: December 16, 2013, 07:12:00 pm »
you replaced a in.k 600 static or graphic and it was installed on an in.xe or in.xm ?
