Author Topic: Hot Spot TX-FreshWater III install QUESTION  (Read 3579 times)
Jas
« on: December 15, 2013, 03:49:28 pm »
Chas and the rest of you Hot Spring bubbas should be able to answer this for me. I just purchased a Hot Spot TX (my first spa) and I'm turning it into a mini JetSetter...I'm calling it a JetSeater. Basically, I'm hooking it up via 50 Amp/220V and adding the FreshWater III Ozonator and a SilentFlo 5000 (E5) 24/7 circ pump.
In my research on the FreshWater III, I understand the Watkins Ozonator Model # 72606 is the one I want because it has an injector (red) that is designed for the Hot Spot spas, i.e. the injector is matched to the flow rate of the pump as Hot Spots do not come with a 24/7 circ pump. But since I'm haveing a circ pump installed, would I now use the Watkins Ozonator Model # 72602 (black injector) that is used with the higher end Hot Spring spas that come equiped with the E5 circ pump.
Thanks! And I will post pics soon of my new JetSeater.
