Author Topic: Cover maintenance  (Read 3141 times)
watzup
  • sipping suds
Cover maintenance
« on: November 10, 2013, 01:47:54 pm »
The outside is pretty simple, mild soap/water and a coat of 303.  The inside (bottom) grey material, I usually have to scrub it pretty much to keep the black (mold?) under control.  Was wondering how others keep the inside clean?  Would 303 be ok on the inside after a good cleaning??
Cover maintenance
rphman
  • Caldera Moorea 07
Re: Cover maintenance
« Reply #1 on: November 10, 2013, 07:39:28 pm »
Don't know about 303 underneath?? I use 303 on top and in 6 yrs have never done anything on the underside of my cover and have never had any mold or anything on it.
« Reply #2 on: November 11, 2013, 07:25:00 am »
I too suspect that 303, as great as it is, would leave a residual behind on the inside of the cover that would work its way into the water.  I'd never had a mold problem inside the cover, I assume there is enough chlorine gas present to keep it clean, though I try to run the jets awhile before closing it.
« Reply #3 on: November 12, 2013, 02:57:54 pm »
Get an empty spray bottle and fill it with a 50/50 mixture of distilled white vinegar and water.  Works really well and is environmentally friendly.
watzup
  • sipping suds
« Reply #4 on: November 12, 2013, 03:40:19 pm »
I'll give that a shot.  Tx
« Reply #5 on: November 12, 2013, 04:11:28 pm »
That does sound like a good idea, and the worst case, it may drop his PH a little.
