Author Topic: Morgan Spa severely overheats after power failure  (Read 2311 times)
nogbody
« on: September 30, 2013, 01:54:29 pm »
Hey y'all first time poster here.
I have Morgan Spa (not sure the model, but it's probably from early-mid 2000's. (Maybe a Morgan II Deluxe Digital Dual Pump) Everytime theres a power failure the spa comes back on, the display is blinking and the temperature is set to some ungodly hot degree like 190... And the spa tries to get there!!! I usually find it then at about 116-120 and I freak out. If I lower the temperature down it turns off, and of course once I pass 104 on the way down it won't let me increase it past 104. Plus the display is blinking but I think it does that after a power outage by design.
Do any of you know why it would be doing this? Is this a electronic failure? Do i have a setting off? I've checked the manual that I found on line, but there's no metion of setting like this. It just seems so weird that it would set it self to such a high temperature, and it only happens after a power outage.
Thanks for any input before I have to call a repair man (i'm pretty handy and would like to do it myself if possible.)
« Last Edit: September 30, 2013, 01:56:25 pm by nogbody »
Re: Morgan Spa severely overheats after power failure
« Reply #1 on: October 01, 2013, 07:25:35 am »
Welcome to the forum. That does sound like an electronic failure of some sort. Has it always done that?  I've owned two tubs, the first one defaulted to 95F after a power failure and my current tub remembers the user setting on power up.  I've been around a lot of electronic equipment with programmable read only memory and on rare occasions when something happens to it, it usually fails outright, but I suppose its possible the value in memory got scrambled.
nogbody
« Reply #2 on: October 01, 2013, 11:11:14 am »
No its only started doing that in the last few months.... I've left it off for 48 hours hoping to clear out anything. I guess there's no way to "reset" the memory?
