Original
Belize FLO ERROR CODE
Pages:
2
3
Topic: Belize FLO ERROR CODE (Read 13571 times)
codfishhead
Junior Member
Re: Belize FLO ERROR CODE
Reply #15 on:
October 04, 2013, 10:54:09 am »
By the way, I tried getting the OEM of the sensor from Spa Depot but can’t get anyone that has that kind of knowledge or access to old parts vendors. Seems Belize is Spa Depot per all their site contact info brings me right back to Spa Depot and no help. If I can find out who manufactured this I’ll be able to find it from there.
Reply #15 on:
Ultimate Member
Reply #16 on:
October 04, 2013, 02:50:39 pm »
Quit focusing on the spa itself, it's the equipment which is Gecko. Might take you in another direction.
codfishhead
Junior Member
Reply #17 on:
October 04, 2013, 03:57:45 pm »
JJ I'm not gay but I think i love you.
Hot on the track now. THX much
codfishhead
Junior Member
Reply #18 on:
October 11, 2013, 09:36:12 am »
Well I changed the sensor and still have the FLO error code.
Any other ideas of what it could cause a FLO error if not the Flow Sensor? Everything seems to work fine. Pumps, pressure, heater core. If I push the pump button it starts up and runs fine. When the 20 mins is over it doesn't go into the slow mode or cycle. That’s when the FLO error pops up. Hit the button and it runs fine again for 20 mins.
Ultimate Member
Reply #19 on:
October 11, 2013, 10:49:07 am »
You try running it without a filter?
codfishhead
Junior Member
Reply #20 on:
October 11, 2013, 04:34:30 pm »
Last night I only switched the senor. Just now I replaced the entire heater core assy. And yes I just tried it all again without the filter in.
When I first turn the breaker on it runs through and the panel shows 3 dashes stuck on with 2 lights flashing on the side. Shuts down in 1 min and the dashes stay on the panel screen. I hit the power button and it fires up in high (2 speeds low and high always started on low never high). The temp is showing steady on the screen. runs for 20 mins on high then stops and FLO comes up on the screen and stays. If I hit the power again it goes for another 20 mins. No loss in power, flow, or anything else while it's running.
Any clue what I can do next?
Ultimate Member
Reply #21 on:
October 11, 2013, 09:22:18 pm »
Can you get the main pmp to run on low or not, just high? No circ pump right? All tubs with no circ will run on low spd to heat the water, if it's going direct to high speed on a 2 spd pump (pump 1) some things up with that..
codfishhead
Junior Member
Reply #22 on:
October 12, 2013, 10:23:43 am »
Yes 1 pump and it won't go a slow. It looks like a standard pump motor. Same as I just bought for my pool. those aern't a 2 stage are they? I would think the high and low are control by the board.
Ultimate Member
Reply #23 on:
October 12, 2013, 10:56:10 am »
Look at the label on the motor itself. if it's a 2spd pump there will be 2 sets of RPMs listed one should be 1735 low 3500 high something like that. If there is only one RPM listed then it's single spd. I don't think I have ever seen a spa with 2 single spd pumps with out a circ pump.
codfishhead
Junior Member
Reply #24 on:
October 30, 2013, 10:17:59 am »
Sorry. Work took over my life 24/7 for a little.
So do you think this is my flo problem? Slow speed on motor is shot. I'll assume one of the large Cap on the motor is shot. Know a vendor that sells that sells these?
Last Edit: October 30, 2013, 10:21:29 am by codfishhead
codfishhead
Junior Member
Reply #25 on:
October 31, 2013, 11:28:03 pm »
http://m.grainger.com/mobile/details/?R=2MER5
This looks like the starter cap.
Any reason I shouldn't try to replace this? Advise
Thx
Ultimate Member
Reply #26 on:
November 01, 2013, 12:32:45 am »
It's worth a shot vs 350 for a new pump/motor..
Ultimate Member
If it Ain't Broke
Reply #27 on:
November 01, 2013, 06:22:40 am »
Still could be a board problem.
codfishhead
Junior Member
Reply #28 on:
November 17, 2013, 04:30:50 pm »
Both starter capacitors read a little below their tolerances. I thought I had it.
Put the 2 new Caps on the motor for 26 bucks. Put the entire works all back together for the
time. Same thing. Runs on high only and gives FLO error.
Hey I gave it my best shot. I’ve changed the Flo senor, heater core, starter Caps on motor, and the ground wire. The display and the board are the only things left.
Do I have replacement options for a board setup? Something that will last.
Ultimate Member
If it Ain't Broke
Reply #29 on:
November 17, 2013, 07:56:41 pm »
Here is where I would unplug the temp sensor and plug in a different one and stick it over the side of the tub in the water. If that didn't do it I would unplug the topside and plug in a different one I knew worked. After that your at the board. Assuming everything you did is done right?
Reply #29 on:
Pages:
2
3
Original
