Author Topic: 2 year old hot spot  (Read 4701 times)
hwimbrow
2 year old hot spot
« on: June 17, 2004, 02:43:25 pm »
One of my local dealers has a 2 y/o hot spot.
The story is it's a new spa but has been sitting around the show room for a couple years. The dealer is reputable, long-time in business in the area and I have other professional connection with them.
So it's not one of the new models I can research on the internet.
What's sketchy is, they're telling me there's no warranty becasue somehow the manufacturers warranty is expired.
The board seems to be haunted by a few pros and a bunch of yahoos like me.
Thank you all very much for your help here. This forum is turning into my favorite due diligence resource.
2 year old hot spot
autoplay
Re: 2 year old hot spot
« Reply #1 on: June 17, 2004, 06:17:58 pm »
I would be leary of purchasing a spa without a warranty.  What are they asking for the spa? Two,possibly you can purchase a warranty through your dealer(in writing of course).?.
BTW.....the Hot-Spots r a clone of Calderas starter line of spas
Rboehme
« Reply #2 on: June 17, 2004, 07:17:33 pm »
Do not buy a spa from a dealer without a warrantee.
« Reply #3 on: June 18, 2004, 01:47:41 am »
A heater for that tub will run ya about $200 installed. Less, actually, but let's keep the numbers nice and round.
If the pump gives you a problem, it will most likely be a seal that needs to be replaced, not the motor. That seal job should be $100 tops.
If a motor does go bad, you're lookin' at $300 installed.
The shell warranty on that tub was only a year or two anyway, and it's a fiberglass-backed acrylic - good history of long life.
So - be sure you're getting enough of a discount, allow for one or two of the above repairs, and you'll be fine. If, in fact, you don't need those repairs, you'll be better than fine.
Rboehme
« Reply #4 on: June 18, 2004, 08:31:53 pm »
Your prices are half that of the dealer in my area. And they wont usually replace a pump seal. They will replace the entire pump. They charge close to $500, NOT installed.
It is a good idea to ask you dealer about the prices of these items and what they charge in labor and other service fees before you buy a product with no warrantee. Of course, if you do not get the prices in writing you should not be suprised if they go up when something breaks.
drb
  • Official 4 Star "Best of Class" spa searcher... ;)
« Reply #5 on: June 18, 2004, 08:58:00 pm »
Let me guess - you live near a large body of water, and your dealer has a magnificent sailboat.  Right? ;)
Rboehme
« Reply #6 on: June 18, 2004, 09:01:30 pm »
No, he is just expensive. ;D
« Reply #7 on: June 18, 2004, 09:08:53 pm »
I think you could easily get these jobs done for the price I mention. As to replacing the whole pump over a $10 part - yes, sometimes companies will do that under the warranty. But this tub has no warranty, so call in a good repair guy and have him put in a new seal, and a couple of O-rings and you're good to go.
All of this is only going to matter if the tub has problems - most don't.
Rboehme
« Reply #8 on: June 18, 2004, 09:15:58 pm »
As a good repair guy, if I was asked to fix this spa in my area I would have to buy the parts from my local dealer. Or I could drive to a different area to get them(also expensive). The sad fact is that if you are in a dealers protected area and they charge alot for thier parts you WILL have to pay alot.
« Reply #9 on: June 18, 2004, 09:26:04 pm »
Why? The element in a HotSpot is a standard, off-the shelf flow-through element. Call spa parts express, or go to PoolandSpa.com, SpaBabe.com, Horizon spa parts, or any wholesale supply house. This tub doesn't have the standard HotSpring stuff in it - it's a Gecko pack and heater. The pump takes a regular seal and some o-rings. Standard stuff.
Rboehme
« Reply #10 on: June 18, 2004, 09:36:29 pm »
You are correct. I wasn't thinking.
Worst case scenario on this spa is, if you had to replace everything(pump, board, and heater), you are looking at approx $1000.
If you are saving more than that it is a good deal.
If you aren't, spend a little more and buy a new one with a warrantee.
