Author Topic: Accidentally put cartridge cleaner in hot tub  (Read 5180 times)
janeav
« on: September 15, 2013, 08:29:18 am »
I have a jacuzzi j345, and use Rendezvous Spa Specialties chemicals.... this morning, I grabbed the wrong bottle and poured 2 ounces of Minute Rinse directly into the tub instead of Protect Plus.  Looks like I poured bubble bath into the tub.  What should I do?  Thank you in advance for your help.
Re: Accidentally put cartridge cleaner in hot tub
« Reply #1 on: September 15, 2013, 09:34:31 am »
 Drain, then fill if still there.  Repeat.    I had a lady pour 16oz of filter clean in her spa, took two draining's and refills to get rid of it, but her filers were really clean  ;)
janeav
« Reply #2 on: September 15, 2013, 09:54:26 am »
Ugh....I was afraid I was going to have to do that....  :P
Thank you!
« Reply #3 on: September 16, 2013, 07:14:54 am »
Thank you!
If you don't the water will foam up greatly when the jets are running. I might even go as far as to say as your tub is draining, take a hose and rinse the sides of the tub as it drains to get the last residual bit of it.
