Author Topic: anti foam alternative ?  (Read 8671 times)
Purpleboy
Re: anti foam alternative ?
« Reply #15 on: June 12, 2018, 05:52:18 am »
Zilibon cleaning defoamer(http://www.zilibon.com/), this product is mainly designed for the foaming characteristics of the cleaning industry's cleaning process, use this product can effectively control the cleaning agent to produce foam.
Mainly used for cleaning and defoaming of various cleaning agents such as yellow robe cleaners, equipment cleaning agents, neutral degreasing agents, parts cleaners, detergents, degreasers, household detergents and electronic cleaning, etc..
Performance performance
Good mutual solubility with cleaning agent, no floating oil, no silicon spot.
Use less, high efficiency, alkali resistance.
The unique defoaming effect is conducive to wastewater discharge.
This product is non-toxic and odorless, which is conducive to production safety.
Instructions
Diluted with clean cold water 2 to 5 times, select the foaming point, add by adding drops can achieve defoaming requirements. The general usage is about 0.2 to 1 inch. Production cleaning agent according to the surfactant content of 2 ~ 5 ‰
storage method
This product is non-toxic, non-flammable and explosive products, stored in a cool, sheltered place, sealed. The storage period is 6 months without obvious stratification. The storage time exceeds the best use period marked on the label does not mean that the product can no longer be used. However, to ensure product quality in this case, it is necessary to re-examine the relevant nature of the product.
Reference data
Appearance: Milky white liquid
pH: 6±2
Working temperature:0~120°C
« Reply #16 on: June 16, 2018, 01:06:17 am »
I had a customer who said they got results from fabric softener. I have never tried it, but you guys seem to be pretty good at searching for all the specs on things - why not check out the specs for a couple of brands of fabric softener?
HTH
 8)
