Author Topic: flo error - gecko artic spa  (Read 17710 times)
Water Boy
Re: flo error - gecko artic spa
« Reply #15 on: September 04, 2013, 01:26:24 pm »
theres no pressure switch guys
If he has a Arctic Spa, then there should most definitely be a pressure switch...
Ryan VSO
« Reply #16 on: September 04, 2013, 02:40:59 pm »
Geez guys theres no pressure switch in.xe if its not working you have to change the pack but i doubt that this is the problem as in.xe are very reliable
Water Boy
« Reply #17 on: September 04, 2013, 03:01:09 pm »
Well. maybe I don't know what I am talking about then :-[. I know here in the US, every Gecko pack we have out there has pressure switches with them. I am guessing that this version of Gecko may be a European version, which doesn't require pressure switches. It that is the case, then it most likely is the capacitor on the motor then.
Ryan VSO
« Reply #18 on: September 04, 2013, 03:22:47 pm »
old gecko pack ( m-class or s-class ) does have pressure switch but the new generation ( in.xe & in.xm ) does not .
Water Boy
« Reply #19 on: September 04, 2013, 03:25:42 pm »
Yes I went and did some digging, and you are correct Vortex. Please accept my apologies. I am obviously not familiar with the in.xe spa packs. We don't sell the new Gecko packs any more, and exclusively use the Arctic Eco packs, so I am not up to speed on the new versions of Gecko. My bad for assuming! ::)
 I am pretty confident that this is the capacitors in the motor after learning this now. Thanks for correcting me!! ;)
« Last Edit: September 04, 2013, 03:34:09 pm by Water Boy »
hawkella
« Reply #20 on: September 04, 2013, 07:54:04 pm »
Pressed no.1 pump switch for over a minute all I got wad L4. My in.xe manual says that L will show up but says nothing about LL
Ryan VSO
« Reply #21 on: September 04, 2013, 08:19:12 pm »
l4 is the good setting for your system . on the xe , those sensor can get blind because of the calcium accumulation , you can find a product to clean it , make sure you dont have any air lock tho
hawkella
« Reply #22 on: September 04, 2013, 08:24:47 pm »
Yep I will clean it. It will take a few days - I will post how it goes. Thanks for your help
hawkella
« Reply #23 on: September 09, 2013, 08:56:56 am »
I changed the low speed capacitor for the pump, uninstalled the in.flo sensor the reinstalled and touch wood all seems fine. I believe it was yhe capacitor . Thx for the help and hope this helps someone
