Author Topic: coast spa lanai  (Read 1909 times)
kingbuzo
coast spa lanai
« on: September 02, 2013, 12:38:49 pm »
tub is 2001...it has 2 pumps...#1 pump is tripping breaker, #2 pump is fine....can i get this tub going by switching #2 for #1?  i know that the other pump runs different jets etc...but it looks like #1 pump is the main circulation pump......
panel shows "flo" which is no water flow .....will it still error if i switch pumps? or does it only error when there is no circulation ?
coast spa lanai
Re: coast spa lanai
« Reply #1 on: September 02, 2013, 01:26:36 pm »
Pump 1 probably also activates the heater, and if so the problem is more likely a bad heater element.
kingbuzo
Re: coast spa lanai
« Reply #2 on: September 02, 2013, 02:08:48 pm »
thanks dr , i disconnected the easy connect of pump #1 and the gfi didnt trip.... i removed the #1 pump and the shaft was frozen... i managed to free the motor and reinstall , but still trips breaker...
i was feeling that i need a new pump motor...
are you saying that the pump activates the heater....so if the heating element was gone then the pump wont work and the gfi could trip?
can i switch pump #2 with #1 ?
 is pump #1 the main pump?
and #2 is just for jets?
thank you
kingbuzo
Re: coast spa lanai
« Reply #3 on: September 02, 2013, 05:53:17 pm »
ok i changed the start capacitors and start switch from good motor to bad.... and breaker still tripped on #1 motor...looks like it need a new motor....ideas?
Re: coast spa lanai
« Reply #4 on: September 02, 2013, 09:00:28 pm »
In order for the heater to operate, water has to be flowing through it. The pump turns on, pumps water through the heater ,and activates it, turning it on.
A motor that doesn't start turning (frozen bearings, or?), can also cause a breaker (GFCI or otherwise) to trip.
Re: coast spa lanai
